RV.Net Open Roads Forum: Travel Trailers: Dump Station Etiquette???
 > Dump Station Etiquette???
Page of 8
dodge guy
Bartlett IL
Posted: 02/08/21 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
GDS-3950BH wrote:
Prior to @ 2010 or so, the vast majority of RVs left the factories without tank flushing contraptions. If you wanted such a gizmo, you added it yourself. Most never bothered to do so. I wonder how everyone survived without them? They work really great ( not sure at what as many are mounted to spray against the gravity flow of the tank outlet) until the cheap plastic anti siphon valve, typically buried in a cabinet somewhere does not seat, and you're mopping up the puddle on the floor. Then not so much.
No need to twist a story into a horror movie! LOL
they are easy to install as I have installed them on 2 different new TT`s. everything is exterior. On my class A its also separate of the living area. no messes and no smells from the black tank either!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Posted: 02/08/21 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
bpounds wrote:
I avoid dump station lines whenever possible. But sometimes on longer trips it has to happen. I often use my gray water to flush my black tank. All it takes is a twist on valve at the end of the plumbing.
Open twist-on, open black tank and drain. Close twist-on, leave black valve open, then open gray valve. Gray water will back flow into the black tank. You'll hear it, and when the whoosh stops, close the gray valve. Open the twist-on and let the black drain again. Finally close the black valve, open the gray and/or galley and finish the job.
While all that is going on, no one in line will know anything about a flush going on. And you'll be there watching and working the valves the whole time.
I'm no RV expert and this certainly will do a bit of a black tank flush, but I like the thought of the gray flushing all the poo out of the stinky slinky after the black tank drains, considering it's the drippy, gotta unhook it and store it somewhere part of the equation.
Not sure I want corn and TP sitting in the slinky until next time.
2017 Heartland Torque T29
GDS-3950BH
DC
Posted: 02/09/21 02:06am Link  |  Quote  |  Print  |  Notify Moderator
No need to get your panties twisted into a knot LOL.
Your self installed contraption may have everything on the exterior, but factory installs almost always have a cheap plastic vacuum breaker / anti siphon valve installed in a dead space in the interior, typically buried inside a vanity cabinet. They are notorious for sticking or not seating and flooding campers.
Those cheap valves are also capable of holding just enough water that if not winterized / blown out they crack, which is not found until spring when the tank flush is used.
* This post was edited 02/09/21 03:18am by GDS-3950BH *
Cummins12V98
on the road
Posted: 02/09/21 02:53am Link  |  Quote  |  Print  |  Notify Moderator
"Your self installed contraption may have everything on the exterior, but factory installs almost always have a cheap plastic vacuum breaker installed in a dead space in the interior, typically buried inside a vanity cabinet. They are notorious for sticking or not seating and flooding campers."
So true! I ditched mine that were leaking with a few pcs of PVC.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
bpounds
Sophmore Brain...
Posted: 02/09/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
It still does clean the slinky. Assuming you had a good amount of gray to dump. Gravity being gravity, not all that much flows over to the black tank. It just finds its own level. In my case I have gray and galley, so plenty of non-black to do both jobs. Once you've got the twist-on valve. Its maybe 3 minutes extra time.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Kavoom
Kansas
Posted: 02/09/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Good etiquette recommendation. Don't cuss, might be kids in the vehicle behind you.
Kavoom
Kansas
Posted: 02/09/21 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Great advice from guy was to flush a bit of fresh water into the black tank after emptying, not much and then put a couple of bags of ice in there down the poop chute before a day run. You will have just a couple of gallons and the ice will slosh around cleaning things up. After about a year, I did this and got some lights back on my black tank status checker thingy. I do this now a few times a year...
36guy
Princeton
Posted: 02/09/21 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
I own a diesel pickup, I always have a pair of leather gloves to fuel up with, so.....I pull up, put on my leather gloves, haul the slinky out of the back bumper, pull the black, wait, close the black, pull the two greys, wait, shut the valves, pull the slinky, into the bumper, climb into the truck and get out of the next guys way. Drag my five gallon pail back to potable water, fill it, dump it down the toilet and vacate.
Nobody around? I'll rinse till the black runs clean, hose down what needs hosing, all with leather gloves. It's not nuclear waste, and I don't get it all over me, sometimes though, it can be very entertaining being in line.
profdant139
Posted: 02/09/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
36guy, what do you do with the leather gloves when you are all done? I use disposable gloves from Harbor Freight and toss them after dumping.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
ford truck guy
Pennsylvania
Posted: 02/10/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
X2
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Page of 8
