RV.Net Open Roads Forum: Tow Vehicles: Ram 1500 at Load Maximum Woes
Search only in Tow Vehicles
 > Ram 1500 at Load Maximum Woes
Page of 5
Posted: 02/03/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Jnoflane2, nice work! I’m sure will be a Uuuuge improvement!
PS, don’t mind the haterz...
Interested to hear your take after loading it up on a trip.
Cheers!
2017 Heartland Torque T29
Posted: 02/03/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Question, since you’ve now used 2 different types of the inside the springs airbags.
How much actual load capacity do you think they provide?
Aka, were the old ones pumped up in the first pic?
I’ve now got a coil spring Ram 2500. Brodozer lookin thing. Don’t really need more suspension capacity for most of what I do but it’s got a 6”/4” lift. The rear coils are OE sitting on 4” spacers and truck is leveled. Being rather cushy for a 2500 it also gets a little Carolina squat just hooking my enclosed trailer. Handles great but looks ghey.
Don’t really want the expense of adding real bags and spacers for what little extra support I need. And these bags may be the ticket if they increase the initial spring rate enough
dodge guy
Bartlett IL
Posted: 02/03/21 11:25am Link  |  Quote  |  Print  |  Notify Moderator
In the first pic, I don't see a WD hitch. hopefully you just had it hooked up for the picture.
As far as 3/4, 1 tons riding rough. if you option a ram 2500 with rear air suspension it will ride nice. in fact most all 3/4 tons from the last 10 years ride nice!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
BurbMan
Noblesville, IN
Posted: 02/03/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
jnoflane2 wrote:
Everyone knows that the Ram 1500 has very low GVWR. Well I would go a step further after towing with it for four years, when close to the maximum, it is under-sprung and sometimes dangerous.
I did end up adding air bags, but simply wanted a more stable platform, and I am NOT buying a 3/4 or 1 ton that rides rough when empty. I should also say that I have no intentions to exceed the maximum allowed by Ram.... I just want more firmness and stability.
So...... I added HD Progressive Springs and the Air Lift 1000HD.
Here is what our rig normally looks like when leaving for a camping trip.
Here are the pics of what I did.......
The pic of the truck is a little dark and hard to see, but the Billstein's up front raise the truck 1.8" and the TTC-1223VT Springs raise the rear 2". Those are 34's on those 20" rims.
Can't wait to hit the road on our next camping trip. Since I have added the necessary bits and pieces to our camper to make it "Four Seasons", we will take it up to the mountains a couple of times in February and March, as a base camp for a long weekend of skiing.
Great job! Now it sits level when it's overloaded!
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
LITEPHIL
AZ
Posted: 02/03/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Overloaded. Need a bigger truck to be safe and within numbers. No hate
2019 Chevy RST Silverado 1500
1954 Chevy 3100 Carryall 4x4
2002 Sandpiper T22
04 FXDL Harley
TurnThePage
North ID
Posted: 02/03/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
QCMan wrote:
I didn't see where you upgraded the parts that actually do the work, the axle shafts and bearings. Sorry but I cannot understand how adding more weight to the vehicle can increase the payload. All you are doing is compensating for the overload. Not any safer at all!
I don't think the parts that actually do the work are overloaded. Just the soft springs. That's the case for my similar setup anyhow.
2015 Ram 1500
2004 Pioneer 18T6
BenK
SF BayArea
Posted: 02/03/21 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Curious how folks know the OP is not over/under his TV’s ratings...
Unless the OP posted actual weights from visiting a scale that I’ve missed.
OP...please post your TV’s GVWR and the RGAWR...then load up as if going camping with the trailer hooked up and weigh it, axle by axle. Then post those numbers.
Otherwise, everyone, including the OP is only guessing...
-Ben Picture of my rig
time2roll
Posted: 02/03/21 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
How about drive it on a scale and post the numbers?
675w Solar pictures back up
IdaD
Idaho
Posted: 02/03/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Newer HD trucks will beat you up a little bit on rougher dirt roads, but for the most part they ride just fine and certainly not enough rougher than a half ton to cause any significant comfort difference. The main thing is to air down those rear tires a bit when you're not loaded up.
2015 Cummins Ram 4wd CC/SB
bguy
The Rock
Posted: 02/03/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Did you get rid of the squishey P tires?
Sorry I did not research.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
Page of 5
