RV.Net Open Roads Forum: How I repaired my damaged section of my fiberglass wall
 > How I repaired my damaged section of my fiberglass wall
Flyin Finn
Battle Ground, WA, USA
Posted: 02/03/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Hi all, first, apologies, I haven't been on here for a few years.
I was going through my old photos and ran in the ones from 5 years back when I replaced a large section of the damaged fiberglass wall on my 5th wheel trailer.
I had intended to do a write-up of my experience, but never got around to do it. So now I finally did it and posted it on my website, and I might add, that 5 years later, the repair is holding up well!
I don't recommend this repair, unless you really know you can pull it off.
Since I am logged on here again, hopefully I will spend more time here now. I still use my (now old) 5th wheel, still pulling it with the same old truck [emoticon].
Before and after: [image]
Link to the repair write-up: RV sidewall damage repair
97 Silverado 2500HD Ext Cab 2WD 7.4L towing a 08 Rockwood 8281SS Fifth wheel
BurbMan
Noblesville, IN
Posted: 02/03/21 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Nice job! When I re-did the truck camper, I took off the rest of the side and replaced the whole wall (actually 3 of them) but your trailer would need a LOT more filon. I attached the luann first then sprayed the adhesive on, laminated the fiberglas in place, then trimmed the excess with a router.
Here's my Lance build, summer covid project.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Gjac
Milford, CT
Posted: 02/03/21 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Very nice job. Did you use a contact adhesive?
Monterey, California
Posted: 02/03/21 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
My, my that looks good!
Flyin Finn
Posted: 02/03/21 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
I'm at work now but once home, I will check out the Lance build and comment some more.
It is so long time I don't remember the adhesive. I could try find out later. It is the red stuff in the images. If I remember correctly it is meant for manufacturing application and not available in retail stores. It is sprayed on on both surfaces and let dry then attached together and needs to cure under pressure.
BurbMan
Noblesville, IN
Posted: 02/03/21 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like the same Benders 618 that I used
frankwp
Calgary, AB, Canada
Posted: 02/03/21 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Nice repair job. My last 5th wheel had damage to the same area, though not as large, when a garbage truck clipped the front corner. I had local RV body shop repair it & because I knew exactly where to look, I could see where the filon was repaired, but I really had to look at just the right angle. Good repairs can be done.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
Flyin Finn
Posted: 02/04/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
BurbMan, wow that Lance project was quite a job! Well done!
Lots of similarities with my case although my project time- and effortvise was only a small fraction of what yours was.
I am sure the filon and the adhesive is the same as I used.
Flyin Finn
Posted: 02/04/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Btw, thanks, all, for the compliments. It wasn't a perfect job, but not bad either. It is holding up well, so I am happy.
shum02
Burlington ON CDA
Posted: 02/04/21 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Most factory applications and not perfect either.
Great job!
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
