RV.Net Open Roads Forum: Tech Issues: New smart TV
 > New smart TV
enblethen
Moses Lake, WA
Posted: 02/03/21 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
What inputs are shown on the setup screen?
What method are you trying to connect through? Actual cable from a provider?
Try switching TVs at the video box.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
IAMICHABOD
Sunny So Cal
Posted: 02/03/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
I found on my Smart TV that the power supply had to be off when hooked to campground cable for it to work.
Former El Monte RV Rental
Buying A Rental Class C
way2roll
Wilmington NC
Posted: 02/03/21 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
tedp wrote:
Retired JSO wrote:
Run a length of coax from the working bedroom TV to isolate where your problem is, wiring or TV.
Ran coax from the campground cable direct to the back of the smart TV and it worked. So it means it's in my switch box I guess. Right?
Maybe. If running it direct from the pedestal worked, why do you need the switchbox at all? But if you want to keep the switchbox do you have the input and output the same? Maybe your switchbox isn't compatible or it's malfunctioning.
lap527
Ocala, Florida
Posted: 02/03/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
same here...
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer when needed.
tedp
Waunakee, WI
Posted: 02/03/21 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
That didn't work, thanks!
tedp
Waunakee, WI
Posted: 02/03/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
I thought maybe it was the switch box as well. It works for over the air channels so I switched around the leads from the antenna in and the cable coax in and that didn't work either.
I assumed I'd have to have the switch box so the bedroom TV would have cable as well.
jdc1
Rescue, Ca
Posted: 02/03/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
tedp wrote:
jdc1 wrote:
If you are using a "smart tv", why are you not streaming it via your wifi?
Not good enough wifi strength
I can stream off my phone. At home I can stream off my Netgear wifi module a 100+ feet away.
tedp
Waunakee, WI
Posted: 02/04/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Got it! The switching hub cannot be powered on when using cable.
Thanks for all the help!
 > New smart TV
