RV.Net Open Roads Forum: Tow Vehicles: Death wobble
Search only in Tow Vehicles
 > Death wobble
larry barnhart
wenatchee. wa usa
Posted: 02/04/21 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
seems like any front end that needs work could do a wobble.
chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
rhagfo
Portland, OR
Posted: 02/04/21 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
spud1957 wrote:
theoldwizard1 wrote:
FishOnOne wrote:
Having said that any solid front axle vehicle has the death wobble potential.
100% correct !
Yeah. This is no way just a "Ford" problem. Any truck with a solid front axle. Google Ram death wobble.
Actually I think Ram passed the “Death Wobble” torch to Ford as of late.
The only vehicle that I ever had death wobble on was a 64 Ford Econoline with bad King Pin bushings.
garyp4951
TN
Posted: 02/04/21 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
There are several things that contribute to death wobble, but the main one is the wrong geometry between the pitman arm, and the tie rod, and can happen on solid axles, and independent suspensions.
Posted: 02/04/21 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
chevman
Eh not really. A solid axle develops the harmonics or whatever it is from one wheel to the other because no only are they tied together by steering but physically through the axle so whatever 1 wheel does pushes the opposite one the other way.
An ifs can shake or rattle but generally won’t get out of control.
PastorCharlie
NC
Posted: 02/04/21 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
My 87 Jeep Wrangler YJ started the death wobble a few years back and I took it to a national tire shop and they did an alignment but it still had the wobble. Took it back to them and they rechecked it and said they needed to shim the axle so I told them to do so. They said they tried to order shims but could not find any available.
I took the Jeep to a fleet truck shop that only works on big trucks and they agreed if it would fit their machine they would work on it. It fit and they shimmed the axle with shims they carried in stock and it stopped the problem.. I have not had any problem at any speed or on any highway.
Cummins12V98
on the road
Posted: 02/05/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Helped a friend years ago rebuild his kingpins on his Scout. Wobble was horrible even at low speeds.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted: 02/05/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
This was likely a caster issue. Lifted springs?
Yes many things can cause it.
spud1957
NB
Posted: 02/05/21 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
100% correct !
Russ I guess you didn't Google Ram death wobble. It is not just Ford. Also Jeep as well.
PastorCharlie
NC
Posted: 02/05/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yes leaf springs and front end is in excellent condition. Just illustrating that improper alignment can also cause the problem. Not just any shop can correctly align one.
GWolfe
Kansas
Posted: 02/06/21 05:28am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2018 F250 at work that suffered from the death wobble. It had just over 20k miles on it when it started. Ford added or replaced the steering damper, aligned it, and recommended new tires. We put new tires on it after getting it back from Ford and all is well, for the most part. We are at 35k now and it is starting to come back, a minor shaking can be felt momentarily through the steering wheel after hitting bumps/expansion joints on the highway. Probably could use another alignment, it is a work truck and gets driven like one.
2005 Sun-Lite Eagle
2011 Silverado
 > Death wobble
