RV.Net Open Roads Forum: Fifth-Wheels: polyurethane refinish for dining table?
 > polyurethane refinish for dining table?
obie311
Aux Arcs
Posted: 02/04/21 11:58pm Link  |  Quote  |  Print  |  Notify Moderator
I put a dish just out of the microwave on my wood dining table and it left a dull ring in the finish.
I was wondering if I could lightly palm sand the finish (220>320?grit) and then polyurethane it for added protection?
Has anyone on this forum done this to their unit?
gbopp
The Keystone State
Posted: 02/05/21 03:36am Link  |  Quote  |  Print  |  Notify Moderator
Did you try mayonnaise on the mark?
nickthehunter
Southgate, MI
Posted: 02/05/21 04:33am Link  |  Quote  |  Print  |  Notify Moderator
Providing it’s a wood table, yes you can refinish it like that. I would probably use 100 to start, and plan on doing at least 3 coats with 220 between coats.
Sjm9911
New Jersey
Posted: 02/05/21 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Yea, i have done my kitchen table a few times like that. Its a bit of work. And if you dont want to mess with it again, a coat of butchers wax at the end will add a lot of waterproofing to it. I do my home table once a year with the wax now. Kids make a mess.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
TXiceman
Full Time RVer
Posted: 02/05/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Another thing to try is rub the ring with a walnut meat, not the shell. I did this to a ring on out table,
Ken
Amateur Radio Operator.
MURPHY55347
Savage, MINNESOTA
Posted: 02/05/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Google it.
https://woodfurniturestore.co.uk/how-to-remove-heat-marks-from-wood/
Veebyes
Posted: 02/07/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Refinishing our butcherblock kitchen table is on the 'to do' list after 'somebody' spilled acetone, or maybe something similar on it. Stripped the polyurethane right off it.
Must be at east 30 years of daily use on that table & still was looking OK. Must have put 4-5 coats on it.
I guess it could be 'patched' but that would result in coating of vastly different ages on it. Somehow I don't think that will come out well so instead of patching I am going with the complete refinish route.
2007 Alpenlite 34RLR
Rich&Mar
wa usa
Posted: 02/08/21 12:04am Link  |  Quote  |  Print  |  Notify Moderator
I didn't believe this until I tried it myself. I had googled this problem and this is how I found this trick. We had a whiteish mark on our table also about the size of a small pot. Take a steam iron (remember them) with a little water in it, lay a white towel over the stain and run the iron over the towel with steam puffs from the iron, just don't over due it. Ours came out great. Took 10 minutes.
rich
obie311
Aux Arcs
Posted: 02/08/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Did this just even out the dull spot so it wasn't noticeable or did it actually bring out the original luster of the finish?
Rich&Mar
wa usa
Posted: 02/09/21 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
It removed the white mark and looked pretty good as is, but I oiled or waxed the entire table to even it out. Looks just fine.
