joelc
Cedar Point, NC
I put this under Full Timing because we live in our camper 7/365 and need an excellent product. Who can recommend a potable water hose that WILL LAST AND DOES NOT FAIL. I have had poor luck with many hoses that leak at the coupling or have faulty threads, or kink. Who has had good luck and with what hose?
enblethen
Moses Lake, WA
This hose has heavy duty thick connectors. Problem with many hoses they have stamped thin connectors.
Camco at Walmart
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
jorbill2or
Full time
Light weight fabric covered "ZeroG" hose has lasted me 2 years under constant use. I will never go back with a regular bulky hose again. The ZeroG cost a couple bucks more but has done well.
I have the Camco hose above in a container as a spare after I retired it. I Haven't used it only once since when I need a few more feet. Its a nice hose but not very flexible.
Bill
arhayes
We have been full-time travelers for almost 7 years, and I’ve been through several hoses. I got tired of having issues putting a hose away in cool temps, so changed 1 1/2 years ago to to the Apex Teknor Zero G hoses. They are flexible, drinking water safe and easy to handle. A 50’ hose fits in the space of a 25’ rubber one. One other thing I’ve done is add quick connectors to all my hoses and fittings. Makes it very easy to quickly disconnect or add hoses to my supply manifold.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
Dick_B
Palos Heights, IL USA
I think I am still using the same hose that I started with BUT I only use it to fill up the FW Tank and let the pump do the rest.
You are using a pressure regulator at the campground source, right?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
2oldman
south
Recent hose thread
joelc
Cedar Point, NC
I use the quick connectors also. I will look into the above. Keep suggestions coming, they are helping a lot. On the Zero G hose...can it take heat tape in the Winter to prevent freezing?
edited 02/05/21 07:56am by joelc *
joelc
Cedar Point, NC
Thanks 2oldman. I usually look things up from past posts, but this time I didn't. Guess I had brain freeze.
2oldman
south
joelc wrote: Thanks 2oldman. No prob.
QCMan
Independent Republic of Horry
Leaking fittings can be traced to using the poorly designed washers that come with then. Go to a plumbing supply and get washers for washing machine supply hoses or go to a big box store and get "green stripe washers" and 95% of the leaks will go away. The rest are probably from defective or run over ends.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
