markchengr
Seattle
When I did maintenance on large marine engines for a living we were required to have all of our torque wrenches sent out and recalibrated once a year. They do get out of spec with regular use.
Gjac
Milford, CT
Many years ago(1975 or so) my friend and I borrowed his fathers Class C and drove to Florida to stay with my parents in south Miami for two weeks. On the way back we noticed a vibration so we pulled over and everything looked OK. Started the MH again and noticed the same vibration above 5 mph. When we shook the outside rear dual tire it was loose and riding on the hub extension the only thing keeping it on the hub was the fender skirt. We had 3 young kids 2 years old to 5 months old at the time. We saw every stud was sheared completely off when we took off the wheel cover. We were very thankful it did not come off we did not crash with our young kids in the MH. This happened at 1 or 2 in the morning and no one stopped to help. Finally someone stopped to help us going south on I95 we were going north and he found a gas station that was open with no mechanic 20 miles away. The guy running the station had the studs and allowed us to pressed them in. The only thing that we figured is new tires were put on before we went to Florida but the rims back then were just flat if I remember correctly and over about 3000 miles of travel worked loose and the vibration work hardened the studs until they failed. Having said all that I think a TT sees more vibration than a MH or car and if the rims are flat like my boat trailer I can see were that can happen. Rough roads could be 10 times the static loads that those studs can see, all in shear.
Ron3rd
Upland, CA USA
Never had a broken stud in 35 years. Somebody is incompetent
3 TRAILERS by the way
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Groover
Pulaski, TN
One of the characteristics of steel is that it will last forever if the stress applied is kept to less than 50% of yield strength. One you go over 50% it lasts a number of cycles of the stress being applied and removed with life going down as the stress goes up. A bolt stressed at 90% yield strength will last forever if the stress is not relieved and re-applied.
In a proper design a bolt that is properly tightened holds 2 objects together with such force that they will not be pulled apart, thus changing the stress on the bolt. The rigidity of the flat face of the wheel against the flat face of the spindle should far exceed that of the bolts. So, unless there there is a mechanical defect in the flat faces causing them to rock the bolt should not be stretched enough to change the stress on it IF IT IS PROPERLY TIGHTENED. BEING OVERTIGHTENED WILL NOT CAUSE THE BOLTS TO FATIGUE WHILE IN USE or result in a failure while in use. Failure from overtightening should only occur during the tightening process.
Most fatigue failure is caused by bolts not being tightened enough! This allows the wheel to pull away from the hub at times, creating a cyclical stretching/stress increase.
So the failure in use is due to LOW TORQUE, mating surfaces that are not flat or possibly the stretching/shrinking cycle resulting from brakes heating up and cooling off and the different coefficient of expansion of the two metals. Having said that, the aluminum wheels that I just bought have steel inserts in the bolt holes to help prevent this situation.
If my trailer was to have trouble with studs breaking I would make sure that the lug nuts are tightened enough, that the wheel to hub mating surfaces are flat and smooth, that there are steel inserts in the aluminum wheel lug holes and that the brakes are working evenly so that one or two are not getting much hotter than they should.
On edit, one more thing to consider, especially if the trailer did not come with the wheels on it. I changed my trailer from steel to aluminum wheels and had a terrible time finding lug bolts the right length. The lug bolts that came with the steel wheels were too short and all that I could find at the parts houses were too long, in both the unthreaded shank and overall length. I finally found some on Amazon with the right shank but were still too long. I was able to cut them to length. I actually just got that done a couple of weeks ago so it will be a while before I can swear that they are reliable.
edited 02/08/21 07:51am by Groover *
CabinetmakerII
Idaho
azdryheat wrote: I've got 3 axles and have never lost a wheel stud. Perhaps people are using too much torque.
What Dry Heat said! We took our 43' Toy Hauler (retired 2020) to the East Coast and back, to Alaska and back, to Arizona and back for 8 years and never broke a stud. I checked lug nuts for tightness with my star wrench...
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2006 700 Arctic Cat ATV (X2)(Retired)
2014 Kawasaki Tyrex 4LE Side by Side
CharlesinGA
South of Atlanta, Georgia
If you are interested in carrying or owning a GOOD QUALITY CLICKER TYPE torque wrench for torquing wheels, that basically never needs calibration and won't get out of calibration and won't be damaged if you leave the tool set to a torque above zero, then I suggest the "split beam" torque wrenches made by Precision Instruments.
https://www.amazon.com/Precision-Instruments-PREC3FR250F-Silver-Torque/dp/B002XMSFIM
This has an 11° flex head to help with fender clearance and are a one way tool with a non reversing ratchet (so you also need to carry a breaker bar with you). Precision has been in business since 1938 and makes a very reliable tool. We had a number of these at work and the calibration room said they always checked perfectly (there is no adjusting them, they can only be scrapped if bad). I own both the 3/8 drive and ½ drive models. (I actually own about 20 different torque wrenches, with ranging from an 80 in/oz model, thats 5 inch lbs, to one that maxes out at 1100 lb/ft)
Here is the big one being used to torque the ball on my Blue Ox hitch to 450 lb/ft
![[image]](https://www.irv2.com/forums/attachment.php?attachmentid=304374&d=1602473527)
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
CharlesinGA
deleted, duplicate post
ford truck guy
Pennsylvania
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
