RV.Net Open Roads Forum: Travel Trailers: TT brakes maintenance
 > TT brakes maintenance
alexey75
Nova Scotia
Posted: 02/05/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I am looking to do a brakes maintenance next month, and looking for a ways to lift our TT (with 2 axles).
As alternative to use bottle jack (and placing a bunch of blocks under the jack), can I use tools like trailer aid plus or a few blocks under one wheel in order to remove the next wheel?
Won’t it be too much weight on one axle?
Is it a good practice?
Thanks!
jdc1
Rescue, Ca
Posted: 02/05/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
You'll be fine. That's how trailer owners install the spare when we get a flat. No need for a jack. Just drive one wheel up on blocks.
MFL
Midwest
Posted: 02/05/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
That is a good way to adjust the brakes. You can easily get at adjuster, when nothing is in the way. IMO, it will not be too much wt on one axle! I've used my TA plus for this on several trailers, including my FW.
Jerry
MFL
Midwest
Posted: 02/05/21 11:39am Link  |  Quote  |  Print  |  Notify Moderator
DP
Bishop area, California
Posted: 02/05/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
"Just drive one wheel up on blocks."
Absolutely the easiest and safest way.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
QCMan
Independent Republic of Horry
Posted: 02/05/21 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
It just means you will have to do the same thing four times instead of two and you will need to get the tow vehicle involved. I use a bottle jack and two jackstands and have plenty of room to adjust when the wheels are off. A cement block with a 2x on it brings the jack way up.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
BurbMan
Islip, Long Island
Posted: 02/05/21 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I use a bottle jack and cribbing to do one side at a time with jackstands. In this pic there are also jackstands under the axle because I was replacing the shackle bushings and equalizers.
If you going to pull the wheel and check the brakes, it's smart to re-grease the wheel bearings and also check the shacles and suspension parts. Many/most OEMs use very cheap components that wear out quickly.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
trail-explorer
NM
Posted: 02/05/21 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a decent video on brakes and bearings
Bob
alexey75
Nova Scotia
Posted: 02/05/21 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys!
BurbMan, what do you mean? “check the shacles and suspension parts”
Just to see it looks normal? Is there anything else to do/inspect during this work?
It will be my first time, I’ve planned to clean inside the drums and re-grease the bearings.
QCMan
Posted: 02/05/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
The equalizer and spring bushings wear fairly quickly. Right now I am waiting for the rest of my bronze bushings to arrive so that when I take everything apart to swap the equalizer out for an Equa-Flex I can replace all the bushings to work with the new wet bolts all around.
