theoldwizard1
SE MI
The Ford brake controller was jointly developed with Tekonsha.
Retired JSO
North Georgia Mountains
The OEM Ford controller has 3 separate settings of force set in the dash settings then fine tuned with gain set at the controller. Beats the heck out of Prodigy or any other aftermarket controller.
CampinHappy
Odessa, Texas (west Texas)
Well, good news. Got the trailer home in one piece. The truck worked flawlessly even with a 25 mph cross tail wind. Now I've just gotta figure out my speed, gear, and RPM's. I'll post another topic, but I was running around 3K rpm on a slight up hill grade, wind at our back and keeping our speed between 65-70. Sometimes it would be in 5th (I have a 6 speed) when there was a little more "up" it would drop into 4th and run around 3,200. This is in the flat lands of west Texas where there are only long slow changes in grade.
Thanks folks!
CampinHappy
West Texas Region
2021 Premier 29RK, 2017 F-150 pulling it fine
Former covered wagons include:
2007 K-Z Spree 240 BH with triple bunks for my 3 amigos
Formerly a 99 Coleman Niagara PUP
wife version 1.0 (so far ">) 4 boys who have flown the coop ">
Edd505
Elephant Butte, NM
Better than the Prodigy I had in the last one, 3 setting plus electric & electric over hydraulic. Last was great when I changed to disc's from the drums.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Lynnmor
Red Lion
CampinHappy wrote: Well, good news. Got the trailer home in one piece. The truck worked flawlessly even with a 25 mph cross tail wind. Now I've just gotta figure out my speed, gear, and RPM's. I'll post another topic, but I was running around 3K rpm on a slight up hill grade, wind at our back and keeping our speed between 65-70. Sometimes it would be in 5th (I have a 6 speed) when there was a little more "up" it would drop into 4th and run around 3,200.
Nothing to figure out, Ford programmed the computer to do that for you. Put it in tow/haul mode and drive. 70 is a bit too fast for towing any high profile trailer if you care about safety and fuel usage.
Boomerweps
Hills of PA
Yup, tow/haul mode and let the truck figure it out.
Check your trailer tire speed rating. Most are under 75 and many are 65.
I’ve found noticeable mpg differences in each 5mph increments above 55mph from TT vs. wind resistance. Around 65mph is my compromise sweet spot towing the TT for reasonable speed (time getting there) and mpg (10 mpg plus fractions) and not being a too slow road hazard. I say around 65mph because I let gravity do it’s work downhill and not sweat the speed drop too much uphills (but I try to stay above 55).
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
