RV.Net Open Roads Forum: Fuel tank electrolosis rust removal
 > Fuel tank electrolosis rust removal
jjrbus
FT Myers FL
Posted: 02/05/21 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
On my 93 Toyota the gas tank is very rusty inside as noted replacing fuel pump. Outside is rust free. There are replacement tanks available but have a litany of poor quality complaints. One person is on their 5th after market replacement tank. There are no new OE tanks available. I can have a tank fabricated for $600, which I am told is a bargain!
So I have been looking at my options and interested in electrolysis. I have looked at many videos and read numerous articles about this and find one part confusing. When treating metal,say a tool, after the rust is removed a wire brush is used to remove the remaining black residue that is left on the metal. When using the process on gas tanks there is no mention of the black residue.
Why no mention of the residue inside tanks????
Dutch_12078
Winters south, summers north
Posted: 02/05/21 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
You might give this a try. It worked well for me on a 1986 Dolphin/Toyota Class C fuel tank some years ago.
Gold Standard Tank Sealer
Dutch
2001 GBM Landau 34' Class A
#1Flyboy
California
Posted: 02/06/21 06:32am Link  |  Quote  |  Print  |  Notify Moderator
U can have a radiator shop clean & coat your fuel tank or if’s you’re inclined you can get “ gas tank coating “ on Amazon or elsewhere. I urge you to clean your tank TWICE according to the instructions! If you don’t get the tank completely cleaned & completely dry before you coat your tank the coating can come off and you will have a major headache.... I used to clean fuel tanks for a living.
beemerphile1
Ohio
Posted: 02/06/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I've done motorcycle tanks using POR-15. It's a bit of work but I see they also have an auto/truck kit.
https://www.por15.com/por-15-fuel-tank-repair-kit
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
jjrbus
FT Myers FL
Posted: 02/07/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
thanks for the responses. The sump has 2 small channels under it, which I assume it to keep fuel from rapidly leaving the sump. I believe I can clean the channels with compressed air before the tank sealer sets??
There is a 1/4" line exiting the tank which I believe goes to the charcoal canister, inside the tank it is connected to an odd thingy. What is it, will tank sealer plug it? I do not have large hands but I cannot reach it. [image]
