RV.Net Open Roads Forum: Tech Issues: Furnace runs but blows cold
 > Furnace runs but blows cold
Wherever I happen to park
Posted: 02/06/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
The sequence
T-state says "I'm chilly, Warm me please"
Control board starts blower blowing
Sail switch closes when blower is "up to speed"
Solenoid valve opens (Propane flows in theory) and igniter sparks.
Next step is an A/B Most Atwood and Suburbans are B
A: Thermocouple (Flame sensor) sends about 0.480 volts to the control board this causes current to flow and board says "OH. Flame is on" and heat continues till T-stat says "Ah. Nice and toasty, you can stop now" or Over temp cutout cutouts.
B: many Furnaces have a single wire ignition/sense system. in this system the wire carries roughly 1000 VAC during sparking and then switches to Sense lookin for the 0.480 volt DC thermocouple out. IF the TC (Thermocouple) is carboned up it may not get hot enough to generate the needed voltage and current.
Or if the change from Spark to Sense flubs Pop goes the sensor chip
(My theory of what killed mine.. And when I inspected the replacement which came from Dinosaur boards it appears it was their theory as well)
There is a LED on the furnace control board that will flash in most cases if it fails.. Whta is the pattern.
Page two... Even if it is working normally so much air flows it won't feel all that warm
Home is where I park it.
Dusty R
Charlotte Michigan 48813
Posted: 02/06/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
You can remove the thermal couple and check it with a propane torch and DC millimeter.
Dusty
enblethen
Moses Lake, WA
Posted: 02/06/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
OPs furnace should have a flame sensor and ignitor, not a thermal couple.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Teleman
Clayton, CA, USA
Posted: 02/06/21 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Can of air with the tube works pretty good!
I got into the blower with compressed air and cleaned all the contacts but it didn't help. I watched this video which explains the procedure for taking the furnace apart to replace the motor, igniter and burner. My motor is good but I'd have to go through all of this to access the sail switch.
RV Furnace Motor Squealing - Remove & Replace ... - YouTube
www.youtube.com › watch › v=oaTW0oNf6Qw
From what I can tell the blue and white wires of the multi pin connector on the board go to and from the sail switch and high level thermostat. Using tap connectors and shorting those wires would get the furnace working IF either the sail switch or high level thermostat were the problem right? If so I know I have to pull the motor to get to them. If not then it could be the igniter or the board. I guess checking the igniter would be the next step.
* This post was edited 02/07/21 09:08am by Teleman *
RobWNY
Jamestown, NY
Posted: 02/06/21 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Teleman wrote:
RobWNY wrote:
80% of the time, it's the sail switch
I was afraid of that. Are you familiar with this unit and what is involved in replacing it?
Unfortunately no but I have a friend that has had a lot of trouble with his furnace and when the tech came to repair it, I happened to be there. He told me about the sail switch being the issue 80% of the time. I just relayed what I was told. There are RV repair techs that have youtube channels and they have done videos on furnaces. You might try looking them up.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Teleman
Clayton, CA, USA
Posted: 02/06/21 10:43pm Link  |  Quote  |  Print  |  Notify Moderator
I linked to a youtube in the comment above.
Posted: 02/07/21 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Says you? The flame sensor as you call it IS a thermocouple.. I know. I tested mine. I am aware they are often called "Flame Sensors" but there are two or three types of flame sensors. ONE of them, the one Atwood and Suburan both use, as well as my water heater. Is a Thermocouple
Dutch_12078
Winters south, summers north
Posted: 02/07/21 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Thermocouples use two dissimilar metals to generate a small voltage when heated that can be used to maintain the fuel supply for the flame. If it cools down, the fuel supply stops. Atwood and Suburban use thermocouples in their standing pilot water heaters, but not in their DSI water heaters, refrigerators, or furnaces.
Atwood and Suburban's DSI flame sensors work by sending a small current to the ignitor probes that is passed through the conductive flame to be sensed by the ignitor board where it's used to keep the fuel supply valve open. No flame, no current passes back to the board and the valve closes. A common flame sensor failure mode is that the burner lights and then quickly shuts off when the flame is not sensed due to misadjustment, dirt, corrosion, or board failure.
Dutch
2001 GBM Landau 34' Class A
dougrainer
Carrolton, Texas
Posted: 02/07/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
You just have to show your lack of knowledge. Doug
PS. 56,000 posts in 15 years and probably 95% are wrong.
dougrainer
Carrolton, Texas
Posted: 02/07/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
https://m.youtube.com/watch?v=oaTW0oNf6Qw
You do not have to remove the motor to check replace the sail switch. But on a 22 year old Furnace, I would replace BOTH the Sail Switch and the Hi limit switch since they can be intermittant and just messing with a sail switch may make it start working. For a few times. They are cheap so replace both. The Hi Limit can be the cause of your problem. Doug
