RV.Net Open Roads Forum: Maiden Voyage wanted to check on RPM's and Gears in 17 F-150
Search only in Towing
Open Roads Forum  >  Towing
 > Maiden Voyage wanted to check on RPM's and Gears in 17 F-150
CampinHappy
Odessa, Texas (west Texas)
Posted: 02/06/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Went and picked up my new Premier 29RK today in Lubbock, Texas. Empty weight is 6,154 and we only had a little water and two tanks of propane on the way home. Going across very gentle rises and drops around the cotton fields on a dry highway with a generally quartering tail wind of 15-20 here's what I saw relative to gears (I let it do the shifting).
Oh 2017 F-150 5.0 L V8 with 3.73 rear end, stock. Had the towing button pushed. 80K ish miles. Trailer chart from Ford shows 9,600 max.
On flat ground I would see around 70mph with the RPM in the 2500-2700 range in 5th.
On very gentle up slopes I would see it drop into 4th, maintain the high 60's and RPM's would be under 3,500. (Redline isn't until high 5's)
It seemed fine, temps all stayed normal, engine seemed fine at the 3,500 rpm range.
Thoughts/Opinions ?
CampinHappy
West Texas Region
2021 Premier 29RK, 2017 F-150 pulling it fine
Former covered wagons include:
2007 K-Z Spree 240 BH with triple bunks for my 3 amigos
Formerly a 99 Coleman Niagara PUP
wife version 1.0 (so far ">) 4 boys who have flown the coop ">
Posted: 02/07/21 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Sounds about right.
Wont really ever use 6th towing a big sail.
5.0 has a lot of power if you wind er up a little and is perfectly happy at higher rpms all day. When towing heavy I usually locked out 5th and 6th.
2017 Heartland Torque T29
dodge guy
Bartlett IL
Posted: 02/07/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like normal RPM's when towing. 4.10's would keep the RPM's lower on gentle rises. And your towin mileage would increase slightly.
Otherwise sounds good.
But!.........you weren't loaded for a trip. So your only going to get heavier. At least another 1000lbs. Which will put you at 7200lbs.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
MFL
Midwest
Posted: 02/07/21 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I understand, that some people have less time to travel/camp, but just slowing to 63-65 mph would make a difference in RPM, and MPG. Wind resistance is your enemy, when towing. Tailwind ??? Almost unheard of, when towing! It is mostly uphill, against the wind! [emoticon]
Jerry
Bobbo
Wherever I park
Posted: 02/07/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
I agree with MFL. When towing, I set my cruise control at 62. I may speed up to 65 for brief periods to pass somebody, but when I am by them, it goes back to 62.
The reason I choose 62 is that most people drive on a division in mph of 5. They drive 60 or 65 or 70 or 75. By driving 2 or 3 miles over or under that, I am never in a wolf pack. I am always slowly passing the others, or they are slowly passing me. I never bunch up with them.
I did a test with my previous rig. At 60 mph I got 9 mpg. At 70 mph I got 6 mpg. That is a 16% increase in speed and a 33% decrease in gas mileage. My current rig has somewhat higher mpg numbers, but tested out to that same ratio.
Bobbo and Lin
shelbyfv
TN
Posted: 02/07/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
The Tow/Haul works well, IME. Check your payload, though. That can be a limit far sooner than the tow weight.
noteven
Turtle Island
Posted: 02/07/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
It sounds "normal" to me.
The Boss 6.2 engine in my 6 spd F-350 shifts to direct (4th) when it needs to pull.
It runs at 3500 or less rpm 95% of the time in rolling land carrying a 3200lbs full height truck camper while towing a 4500lbs enclosed barn trailer. I usually lock out 6th - tow speed of 60 - 65mph is easy to maintain in 5th and 4th without the constant shifting in and out of 6th.
It is happier on 91 gas vs 87 when towing.
If it wants to downshift to frantic mode I select manual mode and hold gears without running the engine to the red line.
Manual mode is available with cruise control on - it's a nice feature.
Williams AZ area
Posted: 02/07/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
“I let it do the shifting.”
As much as I like shift the 1500 (and the Tahoe before it) the vehicle does it better.
CampinHappy
Posted: 02/07/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
MFL - I live in west Texas so there's always a wind. With my previous trailer and this one as well, I literally look out a few days before a trip and plan my times accordingly. This weekend from Odessa to Lubbock the forecast was for 22-25 mph out of the North up till around noon with decreasing in the afternoon, so I scheduled my pickup at noon, with a couple of hours to go through the trailer I ended up with a 15-20 mph tailwind as we came south. I agree that mid-60's is usually the max, but the tailwind seemed to help the truck hit the "groove" at around 68 or so.
Thanks for the replies!
time2roll
Posted: 02/07/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
All looks good. No worry unless the transmission is hunting or shifting frequently to find the right gear.
675w Solar pictures back up
