RV.Net Open Roads Forum: Fifth-Wheels: Mega Cam Ram 3500 and towing fifth wheel
 > Mega Cam Ram 3500 and towing fifth wheel
Cummins12V98
on the road
Posted: 02/08/21 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I don't have to worry about any clearance issues....CHECK
I have a DRW.....CHECK
I have lots of back seat space.....CHECK
I have room for a 30" front to back toolbox and plenty of other room.....CHECK
How is this possible??? Simple, I have a LongBed.....CHECK [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Njmurvin
Simi Valley
Posted: 02/08/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
With the Andersen, if you try to max out the offset from the cab (both hitch and adapter locations) you need to confirm you have clearance from the back of your pinbox to the sides and tailgate. You can gain over 9" clearance if the back of your pinbox won't make contact with the sides on extreme turns or tailgate when driving straight. In the Andersen installation instructions, they take you through some some measurements to determine if you're going to clear. I have a pretty short pinbox that allows me the maximum offset.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
cummins2014
Utah
Posted: 02/08/21 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
It cleared just fine with my 2014 Ram 3500 , with my Montana fifth wheel hitch to rearward position as well as the adapter , with this new fifth wheel it was further from my cab, with the pin box being a bit further out, so I turned the adapter around ,putting it 8" closer to the cab. Turning the adapter is an 8" swing each way . The hole in the adapter to mount to the kingpin, and the hole that goes on the ball has a 4" center .
blofgren
Surrey, B.C.
Posted: 02/08/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
The Megacab DRW is a sweet truck; we love ours!
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
cummins2014
Utah
Posted: 02/09/21 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Do you have the Megacab, converted to a long bed [emoticon] That is the subject here ,towing with a Megacab, nothing mentioned about a long bed that I read . I think by now if someone is after a long bed ,they would certainly get one, its not like they don't have a choice here. I have had several long beds over the years . I don't want one ,don't need one , don't like them ,and will NEVER own another long bed . I suspect many feel the same way, or they wouldn't get a short bed ,we all would be driving long beds .
cummins2014
Utah
Posted: 02/09/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
As said you have the best of two worlds , DRW if needed ,and a "SHORT BED" which many prefer. I started out with towing a fifth wheel with a short bed ,when it was time for a new truck ,the choice was still a short bed , and if I would have needed DRW ,then it would have been the Megacab.
I am sure , you are like many ,you don't want a long bed , if you did you would have one .
blofgren
Surrey, B.C.
Posted: 02/09/21 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
The big deciding factor for me was the CC long box DRW was too long to fit in my garage where the Megacab DRW does. I don't like it sitting outside in the weather!
Cummins12V98
on the road
Posted: 02/09/21 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
What is the wheelbase on a MC and LB Quad Cab?
cummins2014
Utah
Posted: 02/09/21 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have that problem , my garage is deep enough for either . Checking lengths the megacab is 11.1" shorter then the long bed crew cab . The crew cab short bed is 10.9 inches shorter then the megacab . The difference between the long ,and short bed crew cabs is 20"
* This post was last edited 02/10/21 08:52am by an administrator/moderator *   View edit history
cummins2014
Utah
Posted: 02/11/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
The MC being 11.1 inches shorter then yours , I would imagine there can't be much difference in the quad cab. I didn't think they even made the quad anymore, I'll have to look .
