RV.Net Open Roads Forum: Existing air line for RV braking system
 > Existing air line for RV braking system
rvroamerrandy
Yorba Linda CA
Posted: 02/07/21 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Any help on locating an existing RV brake on my coach? I have an air line connection at the rear of my coach but unable to figure out the manufacturer and location of this system. I know it here just cant find it.
2011 Class A Journey 40U
Randy
Ivylog
Blairsville, GA and WPB, FL.
Posted: 02/07/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Should be able to follow a line from your rear axle.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
rvroamerrandy
Yorba Linda CA
Posted: 02/07/21 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
I will set the jacks and start looking around. I appreciate your advice. Keep you posted
enblethen
Moses Lake, WA
Posted: 02/07/21 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
There isn't too many air brake units. This is one,
SMI Brake
Would connect near the rear brakes for connection
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
johnhicks
Wandering below the Gnat Line
Posted: 02/07/21 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
It'l probably be SMI , M&G or Roadmaster. Hunt for a tank/compressor.
-jbh-
oldave
Tx
Posted: 02/07/21 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
The ones I have seen are pretty generic just a small air coupling not special
for any particular brake system.
rvroamerrandy
Yorba Linda CA
Posted: 02/08/21 06:09am Link  |  Quote  |  Print  |  Notify Moderator
well I sure appreciate all of your help and responses. Again, I can see the air line but since I am in the market for a new system I was thinking about going with SMI Air Force 1. I hope this will make that install that much easier. I am towing a 2020 Chevy Trail Boss and I want to make sure I have done everything I can to protect my Investment!
oldave
Tx
Posted: 02/08/21 06:21am Link  |  Quote  |  Print  |  Notify Moderator
If you know what a regular air hose coupler looks like, the thing you would use
to couple an air impact wrench to. My Brake Master coupler on the coach
is about half that size. I think other systems use the same coupler, even if
it is different it will be easy to change.
Bill.Satellite
Full-timer
Posted: 02/08/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
The connection to the air brake line is generic and not specific to the braking system. M&G, Air Force 1 or Blue Ox versions of air brake system will all be able to use your existing connection.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
larry cad
ohio
Posted: 02/08/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
You need a modulated air supply and should probably contact the chassis manufacturer for guidance.
Our Travel Blog
