RV.Net Open Roads Forum: Class A Motorhomes: Loss of rear air pressure
 > Loss of rear air pressure
captron33
usa
Posted: 02/08/21 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
Started motorhome in storage both air systems came up to normal pressure for a few minutes then the rear started to decrease , red light came on an warning horn started buzzing. Cannot locate an air leak . Any guesses what might cause this,
. All air bags fully inflated. Could it be a stuck dryer valve. .?? Where to start looking??
2006 travel supreme, cummins 400 isl.
JRscooby
Indepmo
Posted: 02/09/21 04:23am Link  |  Quote  |  Print  |  Notify Moderator
Most times the air dry is ahead of all systems, so that is not likely. Pressure came up, then went away says you used the air, or it leaked. How cold is it?
Tyler0215
Iowa
Posted: 02/09/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Well you have a leak somewhere. Could be ice in the lines. Did you warm up to operating temp. It may take several times to air up and bleed off to clear the air lines.
MountainAir05
New Mexico
Posted: 02/09/21 08:32am Link  |  Quote  |  Print  |  Notify Moderator
http://constructionpaletizedsystems.tpub.com/TM-9-2320-364-20-2/css/TM-9-2320-364-20-2_965.htm
If yours then check the top RH corner and print it out.
captron33
usa
Posted: 02/09/21 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
It was cold but not close to freezing. Yes it got up to operating temp.
captron33
usa
Posted: 02/09/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure what mountianair 05 is saying.
Stim
NE Florida
Posted: 02/09/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Possible problem with leveling valve. ???
Could linkage have come loose while down?
Valve dirty, some how stopped up?
JRscooby
Indepmo
Posted: 02/10/21 05:14am Link  |  Quote  |  Print  |  Notify Moderator
Not close to freezing? Moist air rushing thru a small hole in a valve can drop temp to form ice.
When was the last time the tanks where drained to remove water?
captron33
usa
Posted: 02/23/21 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Tried running and shutting off engine several times, no help. Still inflates all air bags but rear pressure gauge stays near zero.
wolfe10
Posted: 02/24/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Gauge issue?
If it goes to zero, open the drain valve on each tank. If PSI, start looking for a sender/gauge issue.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
