RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): Battery Meter
Doclocke
Washington
Posted: 02/09/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
The battery status display in our motorhome leaves a lot to be desired, and I've found through experience that I can't trust it when it comes to knowing if the shore cord needs to be attached during winter storage.
I'd like to install a small dial that would be be directly wired to the battery terminals, with an on/off switch to prevent the meter itself from using juice when I don't need it.
Have any of you guys done something like that? If so, where did you find the meter?
Thanks for any suggestions.
Moving-on
mobile
Posted: 02/09/21 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
There are all sorts of things floating around eBay. I believe I'm going to use one of the victron bmv series. But I'm here for better suggestions as well..
agesilaus
North Florida
Posted: 02/09/21 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the AiLi monitor on Amazon
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
KMLsquared
Cotati CA
Posted: 02/09/21 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have installed a BM2 from ebay. No local display but it is bluetooth to your phone. You can check you voltage from bed and it has data logging that allows you to see your voltage on a graph.
This past weekend I knew from bed that my batteries had died at 3 am for some reason. That reason turned out to be low water.
2002 Doge RAM LB QC 4x4 HO 6spd
2003 Rampage 33TB
2007 CRF80F
2006 TTR50E
2004 CRF70
2002 TTR125L
2002 Banshee
1969 Baja Bug
Boon Docker
Posted: 02/09/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Monitor with on/off switch.
DrewE
Vermont
Posted: 02/09/21 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of digital panel meters are available at Amazon, etc. One of those plus a switch would work (though without the needle, of course).
Here is a nice looking analog gauge for battery voltage, with an appropriately sensitive range. I don't think it would be great for your purposes, though, in as much as any converter would peg it on the high side. When operating off of battery power it would be fine; maybe have a momentary pushbutton switch to connect it in under those circumstances. (No numbers on the scale, unfortunately.)
time2roll
Basic LCD meter will use less power than the battery self discharges.
675w Solar pictures back up
theoldwizard1
SE MI
Posted: 02/09/21 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Victron Battery Monitor. Several different models, some with Bluetooth. Not cheap, but probably the best one out there.
* This post was edited 02/10/21 08:23am by theoldwizard1 *
BarabooBob
Baraboo, WI
Posted: 02/09/21 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I use a digital voltmeter that I plug into a cigarette style outlet that I installed just inside the door of the TT. I can also use that socket to charge cameras, flashlights, anything that needs a 12 volt outlet. Cost me about $15 total and multipurpose.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
mbopp
Henrietta, NY, USA
Posted: 02/10/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Yes, my 3-1/2 digit panel voltmeter draws 9ma (.009A). It's hard wired, no switch.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
