RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): Battery Meter
Sandia Man
Rio Rancho, NM
Posted: 02/10/21 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
On our most of our RVs we have kept it simple and used the plug in DC socket type on both interior and exterior of rig, a quick glance and we would have battery voltage and/or which phase our converter was currently charging in. We purchased a better quality unit that displayed battery voltage same as our Fluke, cheaper units were always a few tenths off which could be the difference between bulk and absorption phases. They use such a miniscule amount of power that we never had a need to unplug them, although it was easy peasy to do so.
wopachop
Who run bartertown
Posted: 02/10/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Do you need any additional USB outlets?
Do you plan to get solar in the future?
I have something similar to this. It gives you USB ports, cig lighter, and voltage on a switch.
Dont buy the model i posted. The 2.1A USB is really old. The last USB port i bought was 3.0a and does fast charging. There might even be a newer style.
https://www.amazon.com/Kohree-Charger-Waterproof-Cigarette-Automotive/dp/B07T9HC65T/ref=sr_1_6?dchild=1&keywords=12v+power+panel&qid=1612998095&sr=8-6
dieseltruckdriver
Black Hills of SD
Posted: 02/10/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I used one of the inexpensive ebay meters in my previous 5er, and put the BMV-702 in this one and I like the Victron MUCH better.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
deltabravo
Spokane, WA
Posted: 02/10/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
Victron Battery Monitor. Several different models, some with Bluetooth. Not cheap, but probably the best one out there.
Ditto. It's the BMV-712.
Best one available in my opinion.
Here's mine
Crabbypatty
Long Island, New York
Posted: 02/11/21 04:35am Link  |  Quote  |  Print  |  Notify Moderator
Tri Metric 2030RV. Ive been using it for more than a decade to monotr my Trojan 125's flooded wet cells. %charge, Amps, Voltage, works great. My batts are $900 for the 4 so its a worthy investment.
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
Matt_Colie
Southeast Michigan
Posted: 02/11/21 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Doclocke,
I have this discussion with owners all the time.
You can get a 3-1/2 display that will tell you the Terminal Voltage of t the bank and not much else. Or, you can install a real battery monitor like Bogart or Victron and know what is really happening.
The entire existence of a 12V bank is between 11.9 and 12.8 VDC. If it gets outside of those, there is something wrong and a the voltage tells you is how much trouble you are in at this moment.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
deltabravo
Spokane, WA
Posted: 02/16/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a giant screen I installed over the weekend to read the BMV-712 data via the Bluetooth Victron Connect app
time2roll
Posted: 02/16/21 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
This tells me all I need to know:
675w Solar pictures back up
jrloucks
Ontario
Posted: 03/15/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
I was considering a nice flush mounted voltmeter to monitor the house battery. I even bought one which didn't work (got my money back). I eventually bought a portable cigarette lighter voltage monitor to plug into a cigarette lighter connected to the house battery.
The advantage of this unit is it's portable, and can be removed if the plug needs to be used to power something else. It doesn't require modifying the Systems Monitor, or cutting a hole to mount a more permanent meter. It can also be plugged into the dash cigarette lighter to check the chassis battery charge/status.
