RV.Net Open Roads Forum: Tech Issues: Ladder rung end plastic insert
 > Ladder rung end plastic insert
RVhiker
Posted: 02/10/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Our ladder is a Stromberg Carlson with the ladder rungs that have plastic inserts that have 3 holes for screws. Several of these plastic inserts are broken on my 10 year old ladder. Those inserts cost at least $18 each.
Has anyone found a cheaper alternative, or a way to fix the old broken insert?
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
#1Flyboy
California
Posted: 02/10/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Amazon....
2oldman
NM
Posted: 02/10/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
You might consider replacing the entire ladder.
agesilaus
North Florida
Posted: 02/10/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I'm not visualizing where these inserts are on the rungs a photo would help.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Lake Crowley area, California
Posted: 02/10/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my ladder. They aren’t longtimers.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ItsyRV
Desert SW
Posted: 02/10/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I go to the RV salvage yard and they usually have a bin full of exterior and exterior ladder end caps of various types. They may also be able to tell you what hack is available if unable to find an exact match. They average about $5 each out of the bin (not reconditioned and you match it up) or $10 if bagged (cleaned and labeled).
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
IAMICHABOD
Sunny So Cal
Posted: 02/10/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
WOW they are Expensive
They are a bit Cheaper by the dozen
May be trying to fabricate one using something like this
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
DrewE
Vermont
Posted: 02/10/21 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Do you know someone with a 3D printer?
Alternately, are you adept at shaping wood? A little bit of teak and some careful bandsaw and drill press work might be all you need.
wolfe10
Posted: 02/10/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
$2 each: https://advancedresourcingsales.com/products/cap-step-end
Note: There are two sizes-- need to verify which you have.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
mobeewan
Hampton, Va
Posted: 02/10/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Stromberg+Carlson+ladder+rung+plugs
