RV.Net Open Roads Forum: Tech Issues: Ladder rung end plastic insert
 > Ladder rung end plastic insert
RVhiker
Posted: 02/10/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
I knew where to get the cheap plastic bits at about $20 each; I need four. I always expect to pay way too much for an RV part, but $20 for a bit of molded brittle plastic is really pushing it.
My thanks all who replied and especially to wolfe10 for the following suggestion, where 12 of the plastic bits can be obtained for $24 plus shipping. If I live a few years more, I'll probably need the remaining unused 8 of them.
wolfe10 wrote:
$2 each: https://advancedresourcingsales.com/products/cap-step-end
Note: There are two sizes-- need to verify which you have.
* This post was edited 02/10/21 04:49pm by RVhiker *
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
deltabravo
Spokane, WA
Posted: 02/10/21 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
IAMICHABOD wrote:
WOW they are Expensive
CRIMONY! Even my dealer cost ($9.82) through E-trailer is more than I'd pay for just one ineert.
Dick_B
Palos Heights, IL USA
Posted: 02/11/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Obviously you care about the look.
If you didn't the absolute cheapest thing to do is nothing.
The second cheapest thing is to fill up the space with black spray foam and cut off the end when it is cured.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
RAS43
Littleton,CO
Posted: 02/11/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same ladder and over the years have replaced all of these inserts. Early on they were about a third of what we are seeing now. I don't think the original ladder is available anymore so replacement parts have gotten expensive. Also, I haven't found a replacement that is easy to install the way the original is attached. I still have a couple of spares so hopefully the ladder will outlast my ownership.
And the suggestion to fill in the crack with something is not a good idea as a failure of the insert will cause a bad fall and the crack is the first sign of that failure.
Dutch_12078
Winters south, summers north
Posted: 02/11/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
You make a good point... I'm not sure everyone realizes these are not just decorative caps, rather they are the supports that hold the steps in place.
Dutch
2001 GBM Landau 34' Class A
