RV.Net Open Roads Forum: Class C Motorhomes: 1977 Dodge Sportsman RV
 > 1977 Dodge Sportsman RV
Ashton1012
Washington
Posted: 02/10/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone
I’m working on my 1977 Dodge Sportsman RV with the 360 engine. I have the fuel tank out to clean it, and need to replace the fuel sending unit. Problem I’m having is I can’t seem to find the right one. None of the pictures look similar, and I don’t want to order the wrong one. Anyone able to help me out? I can’t figure out how to attach a picture but I could email one.
wanderingaimlessly
SOBOVA
Posted: 02/10/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
to attach a photo, use this
photo posting
1995brave
San Antonio, TX
Posted: 02/10/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Did you try Rockauto ?
MDKMDK
Canada
Posted: 02/10/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Or, service/parts at an FCA dealership? They may not have one, but may be able to help locate one.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Ashton1012
Washington
Posted: 02/10/21 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip!! Here’s a picture
I’ve tried rock auto. The problem is the closest vehicle I can search is a dodge b300. They came with different sized fuel tanks so idk if the suggested sending units would work. There isn’t really identifying markers on the old one to help either :/
Ashton1012
Washington
Posted: 02/10/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
My next best option is to take it into a parts store to see if they can help me out. Haven’t had time to do that yet so wanted to check on here first
IAMICHABOD
Sunny So Cal 90713
Posted: 02/10/21 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
There is a long running thread on Dodge based Motorhomes,a post over there might get some good answers.
Dodge Based RV
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
Ashton1012
Washington
Posted: 02/10/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Good find!! I made a post on there. Thank you
klutchdust
Orange, California
Posted: 02/11/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
What comes to mind is the size of the fuel tank.I would look up other Dodge trucks with the same size tank and maybe gain some information from that. I had a K-5 Blazer
once and had a difficult time getting motor mounts. Finally a sharp parts counter guy said that during that model year they built that vehicle AND certain catering truck type
vehicles on the same chassis, so next time i ordered parts i ordered them using that information....who knew...
I mention this because sometimes we need to look a little past what we have. A motorhome starts with a bare chassis, drivable, so there's a fuel tank on it. What else could
they use that chassis for, maybe a shuttle bus? That may give you another idea of what to look up.........
Old timer Dave
Quesnel, BC
Posted: 02/21/21 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
If you still want to find the original manual for this motorhome you can find one for two week free rental from the internet archives.
Tip on cleaning the sender unit if that is the cause of you problems, get a spray can of electrical contact cleaner and spray inside the electrical compartment. Exercise the sender a few times and spray again. repeat as needed. then take a Ohme meter to the contact and ground to see if you have a variance in reading.
I don't know if you got the stalling at stop lights and signs sorted out, I would presume after heavy braking. But I would be checking for a "DASHPOT" or anti-stall solenoid. Obviously have the mechanic re torque the carb etc.
I own 1978 empress on a Dodge MB300 chassis so at times have the same problem.
dfhslm@telus.net
Dodge user
