RV.Net Open Roads Forum: Tech Issues: propane connection
 > propane connection
tigtig
perry, ga.
Posted: 02/11/21 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, I have a 2002 Fleetwood Discovery, I want to connect external propane tank so I don't have to pack up and drive to fill the internal tank. I'm not sure what type connector to get. Can someone Please Help.
Thanks
enblethen
Moses Lake, WA
Posted: 02/11/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Where is your tank? Some Fleetwood pushers have it in the center of the coach with a fill port in small hatch.
Normally you would get an Extend-a-stay kit. If your tank is in center of coach don't know how the kit would work.
Extend-a-stay
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Posted: 02/11/21 04:02pm Link  |  Quote  |  Print  |  Notify Moderator
If the tank outlet valve and regulator are where you can get at 'em the Extend-a-stay type adapter is your #1 choice
The link shows the actual adapter. The full kit Comes with both a 10' Tank to grill hose (The Grill end has the same fitting as the top of a "Throw-away" bottle as does the OUT port on the "X" fitting)
And a 5' "Tank to RV" hose that fits the inlet port on the "X" adapter.
The inlet has a small (about a quarter inch) brass threaded hole.
One of the first "modifications" I made to my RV 15 years ago and used both of the extra fittings (Grill side and external tank side)
Check valves protect you from many "Oh ****!"s that can happen.
Flame King adapter only
CA Traveler
The Western States
Posted: 02/11/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Low pressure propane fittings are common on RVs and you may need to remove the BBQ regulator as the use of 2 regulators may give inconsistent propane pressure.
This is my high pressure adapter with a El (for hose routing considerations) and a shutoff valve. The top external tank port is for an additional external tank. The BBQ connector is the standard 1lb 1" screw on propane bottle type.
[image]Click For Full-Size Image.
Hoses with the standard 1” screw on adapters are available. And an adapter for the standard BBQ regulator fitting are available. Propane stores can also make custom length hoses however I use 1 or 2 12' hoses as needed.
Here are the parts that connect to any grill with a external tank port.
2014 Grand Cherokee Overland
Bob
tigtig
perry, ga.
Posted: 02/11/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Yes my tank is centered under the RV, with the fill port on the back right of the RV, behind door
enblethen
Moses Lake, WA
Posted: 02/11/21 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
It is still possible to use extend--stay. The hoses would have to stay in place. Installation would have to be done so has to protect them.
donut dave
Burnett WI
Posted: 02/16/21 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I changed out one of my 30 lb hoses to a 5 footer. when i want to attach it to my 100 lb tank i just unscrew the green coupler and screw it onto the big tank. i got the 5 footer with the green hose as it more flexible during cold weather where as the black hose is stiff. and it is easy to wind up when using the 30 pounder.
