RV.Net Open Roads Forum: General RVing Issues: Slide outs in cold weather
 > Slide outs in cold weather
PursuitAngler
Brentwood, CA
Posted: 02/12/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Headed up to Sierra this weekend. It's supposed to be in the low upper 20' to low 30's at night. It's supposed to rain only one day.
My question is, is it ok to use slide outs when it's near freezing Temps or should I leave them in?
MFL
Midwest
Posted: 02/12/21 07:03am Link  |  Quote  |  Print  |  Notify Moderator
It is okay, but if it rains, turns to ice, could be an issue to close. If you plan to leave in morning, before temp warms up, I'd put slides in before freezing temps.
Slides may operate slower, due to cold, but if no snow, or ice, should not be a problem.
Jerry
tomman58
Southeast Michigan
Posted: 02/12/21 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Slides are not insulated well so thinking you will be using the furnace they should dry out and any snow melted off of them. Their motors, screw drives are all under the unit out of the weather. We never have cared about cold other then we don't want to camp in it but it is a factor in late fall going across the USA.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
rhagfo
Portland, OR
Posted: 02/12/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Typically it is only the floor and roof of a slide that is poorly insulated, the roof is about an 1-1/2” thick, but otherwise no worse than the rest of the trailer.
rr2254545
Central Minnesota
Posted: 02/12/21 08:15am Link  |  Quote  |  Print  |  Notify Moderator
If you have toppers I would leave them in as twice I have had a great deal of trouble getting slices in with ice and snow on them. At 20 I would leave mine in as the RV will heat much better
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee, Air Force One, Blue Ox Avail tow bar
374 Campgrounds,85K miles driven in our Winnebago motor homes and 1858 nights camping since we retired in July 2009
PursuitAngler
Brentwood, CA
Posted: 02/12/21 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Thank you guys very much for the reply.
time2roll
Posted: 02/12/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Yup. BTDT. Had to boil water to get the 1/2" sheet of ice off the slide to close. Furnace set to 90 for a few hours did about nothing.
675w Solar pictures back up
dedmiston
The West
Posted: 02/12/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
We've always left ours out and we camp mostly in the winter. We don't have trouble with wind coming in, but once I almost brought them in because the wind bounced the slides so much.
Usually if it rains where we are, then the temps aren't that low.
We've had snow a few times and it wasn't usually a problem if the snow wasn't prolonged.
One time we were camping near Bryce, UT and we got six inches overnight. That was a problem. We spent about an hour getting as much of the snow off as possible, but the thin sheet of snow on the slides turned into a wet mess when we pulled the slides in and traveled. The bedroom slide drained onto my wife's side of the bed and she had to sleep in the rear garage. Not happy.
So out of our hundred+ winter nights, we got wet once. Seems like a pretty good track record. Less than 1% regret.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
valhalla360
No paticular place.
Posted: 02/12/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
I've found the opposite.
- If you have snow and ice on the toppers, it usually just falls off as they roll up.
- If you don't have toppers, it tries to pull the snow and ice inside where it melts and makes a mess.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rr2254545
Central Minnesota
Posted: 02/12/21 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Guess I was dreaming the two times it happened to me
