RV.Net Open Roads Forum: General RVing Issues: Slide outs in cold weather
 > Slide outs in cold weather
memtb
Wyoming
Posted: 02/12/21 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve never had any slide issue that were temperature related down to well below zero......ice on the slide top could be a concern. I’ve used ours with some ice on the slide top, but try to avoid if possible! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
camper19709
middletown,DE
Posted: 02/12/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have 2 slides with toppers.
Snow and/or ice = slides in. I am unable to access the toppers. No point tempting damage bringing slides in with snow and/or ice.
Severe cold = slides in. Easier to heat.
I am lucky to have access to 99% of motorhome with slides in.
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
12th Man Fan
Flower Mound , Texas
Posted: 02/13/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
If you use your furnace and you have floor ducts you will need to leave the slides out if the slides cover the vents.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
kellem
Shenandoah valley,VA
Posted: 02/13/21 06:59am Link  |  Quote  |  Print  |  Notify Moderator
I've had slides with and without toppers but have always carried a 6ft step ladder just incase.
Toppers are better in inclement weather. Imo
valhalla360
No paticular place.
Posted: 02/14/21 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
rr2254545 wrote:
valhalla360 wrote:
rr2254545 wrote:
If you have toppers I would leave them in as twice I have had a great deal of trouble getting slices in with ice and snow on them. At 20 I would leave mine in as the RV will heat much better
I've found the opposite.
- If you have snow and ice on the toppers, it usually just falls off as they roll up.
- If you don't have toppers, it tries to pull the snow and ice inside where it melts and makes a mess.
Guess I was dreaming the two times it happened to me
Nope, I'm sure you had some sort of issue.
But having had both, I know if you don't have toppers, you need to go on the roof and manually remove the snow and ice or it gets pulled into the trailer when you close the slide.
On our rig with slide toppers, it always just fell of as the topper rolled up.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
joegray
British Columbia, Canada
Posted: 02/15/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Bring them in if ice is forecast. Was south of Rapid City one Sept ,cold and windy. Ice rain started so I brought slides in. Glad I did as we had a inch of ice on trailer in the morning.
