RV.Net Open Roads Forum: Wire gauge for a 200 ft run on 30 amps or 50 amps?
 > Wire gauge for a 200 ft run on 30 amps or 50 amps?
map40
Posted: 02/12/21 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Anybody has a good calculator for wire gauge? I need to do a wire run of 200ft buried wire. I can do 50amps or 30amps. Any advise will be greatly appreciated!
Alfa SeeYa
Life rocks when your home rolls
SAR Tracker
Central Oregon
Posted: 02/12/21 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
wire size calculator (dot) net
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
map40
Posted: 02/12/21 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks! What would be an acceptable voltage drop? 5%?
Old-Biscuit
Verde Valley
Posted: 02/12/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
3% Max Voltage drop for that 200' run
Otherwise you will have Low Voltage any time the supply voltage drops below 115V
50A #1AWG
30A #3AWG
Do NOT scrimp on the wire size...........
US NAVY------USS Decatur DDG31
Cummins12V98
on the road
Posted: 02/12/21 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Don't throw away your money!!! Run the 50A and be done with it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
map40
Posted: 02/12/21 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
50A #1AWG
30A #3AWG
Thanks and thanks for the advise!
2oldman
NM
Posted: 02/12/21 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
advice.
Boon Docker
Posted: 02/12/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
The grammar gods have struck again. [emoticon]
naturist
Lynchburg, VA
Posted: 02/12/21 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
I'll second what @Old-Biscuit said. Don't scrimp on wire. As wire is expensive in those sizes, it is none the less the cheapest part of the whole deal, when you consider also the just the hassle of blown fuses/breakers, brown-out damaged gear, etc.
enblethen
Moses Lake, WA
Posted: 02/12/21 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
3% for voltage drop.
Hopefully, Old Biscuit is indicating copper wire and not aluminum.
Direct burial or are you going to put in conduit?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
