RV.Net Open Roads Forum: Wire gauge for a 200 ft run on 30 amps or 50 amps?
 > Wire gauge for a 200 ft run on 30 amps or 50 amps?
Old-Biscuit
Verde Valley
Posted: 02/12/21 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
enblethen wrote:
3% for voltage drop.
Hopefully, Old Biscuit is indicating copper wire and not aluminum.
Direct burial or are you going to put in conduit?
[emoticon]
US NAVY------USS Decatur DDG31
map40
Posted: 02/13/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
[emoticon]
[emoticon]
I was going to have the GHana Dancing Pallbearers to do the burial [emoticon]
Alfa SeeYa
Life rocks when your home rolls
enblethen
Moses Lake, WA
Posted: 02/13/21 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
You can use a different insulation on the wire that is less expensive if it goes in conduit as compared to USE type direct burial wire was my point.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Cummins12V98
on the road
Posted: 02/13/21 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Still needs to be rated for potential water that can get into conduit.
I thought I was being smart bu pulling romex thru 3/4” pvc that was well glued. After a couple years the hot went to ground.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Matt_Colie
Southeast Michigan
Posted: 02/13/21 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry guys,
I just read the whole thread and I can't sit back any longer.
First: If you don't buy enough copper to do the job right, you may save money now and you will probably pay for it forever......
Second: A 3% voltage drop is meaningless. Voltage drop is Volts Lost and irrespective of the starting terminal voltage. Most of these tables give you that 3% number and don't mention that this is only one way. There has to be a return.
Your current coach is 30A? It is a waste of time to set up for 30. Put in wire for 50. Use 3 conductors but you can save on the neutral and size it for 30 (unless you are firing a Sigma Arc) because when you load the 50, some of the load will be going out the other 50.
Don't bother running a ground unless your local inspector requires it.
Bury a new ground rod at the new service box.
Bury two plastic conduits. Put the service power in one and use to other for communications, like Cat6 or TV coax or ?? (Who know what is next - fiber maybe?) Do Not Use 90s. Split the turn between two 45s.
Think about burying a water line out there too.
Digging is cheap, unless you have to dig it up to do it again.
Do I have to add BTDT????
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
time2roll
Posted: 02/13/21 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
If you use 200', 240v, 35 amps, 3% in the calculator you only need #6 wire. This still allows two large draw items on each side of the panel and plenty of ampacity if you draw close to 50 amps for a few minutes.
675w Solar pictures back up
