RV.Net Open Roads Forum: General RVing Issues: Sticker and residue removal
 > Sticker and residue removal
Diamond c
West ky
Posted: 02/13/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Finger nail polish remover but test I it in a small spot to make sure it only takes off what you want removed
Durb
NW
Posted: 02/13/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I used gorilla tape to hold a failed awning in place. Once removed, the tape left a terrible amount of residue. I used Tech brake cleaner from Walmart to clean it off. I was apprehensive at first but it cleaned easily with no damage to the fiberglass.
This is a testimonial, not a recommendation.
12thgenusa
Loveland, Colorado
Posted: 02/13/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for Rapid Remover. I just redid all the graphics on my trailer in 2019. Ten-year old graphics. Heat gun works to remove the graphics. Actually I found the heat gun too hot even on low, tended to make the graphics too soft and tear apart. I used a hair blower on low and it was just right. One quart of Rapid Remover removed the glue residue from the whole trailer with a little left over, some of which I just used to remove glue remaining from a seven-year old clear bra on a car I am getting ready to sell.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
CharlesinGA
South of Atlanta, Georgia
Posted: 02/13/21 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to ask, what kind of stickers do you want to remove? the large decorative decals? or the stickers at the water fill, Power, the one on the front left with tire sizes, weights, etc on it?
If the latter, think twice before you remove them. The manufacturer installed those stickers for a reason, or several reasons. The large one on the front left, with tire sizes, weights, etc, is REQUIRED by Federal DOT, It would be akin to removing the VIN numbers off your car. The one on the power connection is REQUIRED by the National Electric Code. I don't know for sure, but I suspect the one on the water fill is probably required by some plumbing code. The sticker near the propane bottles is, I think, a DOT required sticker, cannot recall for sure. Code compliance is required by the RVIA who issues the serial numbered oval sticker on the outside near the door. Removing the stickers would certainly prevent the trailer from being exported to Canada, but might also cause issues elsewhere. Supposedly a few (vary rare if actually any at all) campgrounds make having the RVIA sticker (and hence the others) a requirement, to weed out the schoolies, ambulance conversions, cargo trailer conversions, etc.
Possibly I am picky about such things, but.... If I encountered a trailer that were missing such stickers, ESPECIALLY the DOT sticker on the front left, and the RVIA sticker, I would walk away from the deal, even if it were being given to me............
They don't put those stickers on there for the fun of it, the manufacturers do it because they have to. If they could not do it, they would not.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
time2roll
Posted: 02/14/21 12:11am Link  |  Quote  |  Print  |  Notify Moderator
Rapid Remover and an eraser wheel both on amazon. Still a lot of work for 10+ year baked on and pealing decals to get removed.
I removed some of the worst and gave up on the rest for now. Just part of the patina.
675w Solar pictures back up
lwbfl
Florida Panhandle
Posted: 02/14/21 06:57am Link  |  Quote  |  Print  |  Notify Moderator
The advertisements only.
1976 Myself and Wife
1999 DD
2001 DS
2009 DD
2016 Chevy Z71
2015 Toyota 4Runner
2021 Coachmen Apex 253RLS
dedmiston
The West
Posted: 02/14/21 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Charles
Don't forget the mattress tags. [emoticon]
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
lwbfl
Florida Panhandle
Posted: 02/14/21 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I'd hate for the helicopters to swoop in as I'm cutting that one off!
Veebyes
Posted: 02/14/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
First line of the first response hits it pretty good.
Depending on age & material quality the decal will be easy or the other way. A hair dryer or heat gun on low along with patience & a non scratching putty knife of some sort will get the decal off.
The remaining adhesive is the fun part. Yeah, the expensive packaged for the job products work but I like cheap that works. Stuff that might already be laying around. Lacquer thinners dissolve all kinds of things. Acetone is another excellent cleaner that will not harm gelcoat. One more little known cleaner is Naptha. It will remove residue that another cleaner might leave behind.
Finish off with a good marine cleaner wax & the surface should be like new.
2007 Alpenlite 34RLR
Veebyes
Posted: 02/14/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Nail polish remover is nothing but glorified acetone. Try taking her to Lowes next time she needs some. Add some baby oil to it.
See what kind of reaction you get. You might be doing some early season camping.
