RV.Net Open Roads Forum: Tow Vehicles: Towing with F150 Poweboost
Search only in Tow Vehicles
 > Towing with F150 Poweboost
MitchF150
Puyallup, WA
Posted: 02/13/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
MaxTow in my era Eco is 36 gallons. My old 97 F150 with the 5.4 only had a 26 gal tank..
I have not looked at or really have any interest in the 'electric' trucks coming out... I'm old and know I will have to do something at some point, but for now... I don't even want a 15 F150 or newer... ha, ha...
No disrespect for the millions of 15+ F150 owners.. I just like old school and compared to my old 97 F150, my 13 is miles above it... I know the new F150 are miles above my 13, but I'll run the 13 into the ground before I feel I need to get something else.. [emoticon]
Mitch
Boomerweps
Hills of PA
Posted: 02/13/21 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Powerboost is the only F150 with a 30 gallon gas tank. That’s it’s only gas tank option. Battery space has to come from somewhere.
Depending on the wheelbase & cab, standard tow package could have a 23 or 26 gallon tank with the other engines. HDPP & Max Tow get the 36 gallon tank non hybrid.
Bottom line: 30 gallon ain’t bad.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Lantley
Ellicott City, Maryland
Posted: 02/13/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
The technology is amazing. Everything I read is very positive but a 250 mile towing range is a deal breaker.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
JIMNLIN
Oklahoma
Posted: 02/13/21 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
You mention XX mpgs on the flats and xx in the hills.
Those must be your speedo dic numbers.
What kind of average mpgs do you get with pencil/miles/gallons used over say 3-4 tanks? How fast do you tow ??
I never worried with a single tank mpg which is nice to know but a good towing average comes over a few tanks used when towing.
BurbMan
Islip, Long Island
Posted: 02/13/21 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
We had a 2018 Explorer Sport with the 3.5L EB and towed a double axle U Haul trailer to Wisconsin year before last. It towed like a dream and held 70-75 easy on the interstate. But with the 18-gallon gas tank, gat stops were every 2 hours, you could almost set your watch by it.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Groover
Pulaski, TN
Posted: 02/15/21 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
New F150 Powerboosts are not known for fuel mileage when towing. Many, many reports on this issue.
Every test that I have seen so far seems to have been designed to avoid taking advantage of the regen capability of the hybrid. Accordingly, the test results are roughly what should be expected from a non-hybrid doing the same test.
My experience with my two 3.5L Ecoboost engines is that they do burn more fuel than a diesel but noticeably less than my old 460 or V10. In terms of $/mi the Ecoboost is on par with the diesel at local fuel prices.
* This post was edited 02/15/21 11:33am by Groover *
RoyJ
Vancouver, BC
Posted: 02/16/21 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
That there is why us RV'ers will be the last to adopt an EV truck.
It'll be a long time before an AFFORDABLE HD EV pickup can tow a 11'+ tall toy hauler (worst aero wise), at 70 mph, for 250+ miles.
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 02/17/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
If you look at the Tesla semi, they have done a lot of aero work to make it slide through the air resistance better. So maybe HD EV pickups will do that also.
Ford Edge ST Twin Turbo 2.7L V6 335HP and 380 Lb Ft - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome. Retired and enjoying it!
RoyJ
Vancouver, BC
Posted: 02/17/21 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
It's not the pickup truck itself, it's the modern trailers we haul these days. The tall rear section of a toy hauler is the worst possible shape for Cd.
With semis, they have the luxury of designing the tractor and trailer together. A Euro Mercedes hit 12+ mpg @ 88,000 lbs GVW, that's better than some pickups at less than half the weight.
Me Again
Posted: 02/18/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
It would be interesting to put a set of the foldout aero panels you see on the rear of some semi trailers on the back of a tow hauler. I wonder how much that would improve MPG?
I have been down on the companies that gave up rear caps for that reason. Any square corner cause more drag. I went from the 9500 flat back 5th wheel to a 12,400 one with a rear cap and mileage improved.
