RV.Net Open Roads Forum: Tech Issues: PROPANE LEAK??????
 > PROPANE LEAK??????
joelyn
Az
Posted: 02/12/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
have our TT sitting for about a year now since we have not gone anywhere because of the virus... went out to it yesterday and a strong smell of propane by the front of it by the tanks and inside by the front. had my tanks on. turned them both off and smell went away after awhile.. So I assume a leak is going on, but where do I start to locate it..and how????? we live in az where the summers are in the 110 plus temps and TT is in the sun most of the day., could that have dried out any kind of seals if there are any???? No propane devices until mid-ship where there is the heater and than the kitchen is all the way in the back along with hot water heater. its a 28 ft....THANKS..
enblethen
Moses Lake, WA
Posted: 02/12/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
You can use a soapy water spray and look for small bubbles.
Were the tanks off? Were they full? Sitting in sun?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
agesilaus
North Florida
Posted: 02/12/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Get out the soapy water, I actually find something like 409 or fantastic works. Watch this: RV propane leaks
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Itinerant1
Itinerant
Posted: 02/12/21 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Unless the tanks were filled full before storage when cold they could of off gased some when they heated up in the sun.
As others have said soapy water at all joints and look for bubbles to form.
12v 500ah (5,120Wh usable), 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 1,800+ cycles.
dieseltruckdriver
Black Hills of SD
Posted: 02/12/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Spray the soapy water on the hoses also. I would bet that is where the leak is.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
gotsmart
a bit too late though
Posted: 02/12/21 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
409 has ammonia in it. Recommend not testing for gas leak with ammonia-based product.
lwbfl
Florida Panhandle
Posted: 02/12/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Could the just be venting from the increased temps?
1976 Myself and Wife
2009 DD
3 Doggies
2016 Chevy Z71
2021 Coachmen Apex 253RLS
BobsYourUncle
Calgary Alberta Canada
Posted: 02/12/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
I would start by looking at the tank connections. Are they tight?
If so the primary suspect would be the hoses around the regulator. 3 connections there, one of them could be leaking.
As the good suggestions above mentioned, get out the squirt bottle with soapy water and get after all connections.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
joelyn
Az
Posted: 02/12/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
they were about 3/4 full and in the sun in the summer months. right now temps only in the 70's when the smell started... will have to check the soapy water idea, TY...
joelyn
Az
Posted: 02/12/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the video...
