RV.Net Open Roads Forum: Tech Issues: PROPANE LEAK??????
 > PROPANE LEAK??????
joelyn
Az
Posted: 02/13/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
wowens79 wrote:
I keep having to replace pigtails, they start leaking where the fittings are crimped on.
will check them first. thanks
ItsyRV
Desert SW
Posted: 02/13/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
joelyn wrote:
Will check them, I know I replaced them about 3 years ago but like I say the sun out here and 120 deg, temps destroys everything...put solar street lights on the house back in may and by aug they were all destroyed, one even fell off the mounting pole when the sun just made the plastic housing so brittle that it just fell off...
ty
and when you do find and fix the leak, make sure you are coating all the exposed non metallic parts for UV protection. You can use 303 as a general coating that works good on everything or something like TriNova that is excellent for rubber type parts. Unlike hard plastics, the flex parts need that extra protection to keep them from getting brittle and stay flexible.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
enblethen
Moses Lake, WA
Posted: 02/13/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
OP: you did not answer whether the tanks were turned on, or whether the valves were turned off. Please clarify.
It makes a big difference!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
joelyn
Az
Posted: 02/13/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
ItsyRV wrote:
ty
good idea, i have some of that 303 in the garage. even thou my tanks have a cover on them that stuff can't hurt..
time2roll
Posted: 02/13/21 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Get Cavagna brand pigtails for a superior crimp.
675w Solar pictures back up
jimbo4UT
Stafford Virginia
Posted: 02/14/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Gee posters. He had the tanks on for the past year and said so in his post. Also no one seems to think it odd that the smell is strong after sitting for a year?
Tells me the leak is very very new. Brass fittings srink when it gets cold.
First thing i would do is (once you get more propane in the tanks) is simply sung up the fittings, turn it back on and see if the smell comes back. But wait till it warms up into the 50's a few days before doing this. Give the brass time to warm back up.
Wife turned our burner half way on (by mistake of course) while putting a towel under the glass on the stove to keep it quiet as we traveled home late November. Only a 2 hour trip home and never smelled LP. Went to check on batteries a couple of weeks later while in storage and yep no LP in the tank. Filled it up at u-haul and after putting it back in storage i used my LP smell checker and sure enough i also had a slight leak by the regulator (it also got very cold the 2 weeks in storage before i came back)
Sometimes before we tear down the trailer maybe just take a deep breath and check the simple things. Were kids playing in the rv in the past month and maybe turned on a burner, etc. Because of no use for a year yet a very strong smell tells me it was a very recent event of some kind.
Jimbo
dougrainer
Carrolton, Texas
Posted: 02/14/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
To check for leaking pigtails, liberally soak the crimp connections with soapy water. Have BOTH tanks ON. twist and wiggle the crimp connections at the pigtails. Odds are, that is where they are leaking. YES, temp changes can cause those crimp connections to leak. They should NOT with temp changes. It is not unusual to have to replace the pigtails every few years for leaks. The quality of these pigtails has declined in the past 15 years. You want a pigtail that does NOT have a round ring clamp. Those are the worst. Also, keep the pigtails covered from the sun. UV causes a lot of problems. LAST, NEVER LEAVE LP ON, ALWAYS TURN THE TANKS OFF. Doug
dougrainer
Carrolton, Texas
Posted: 02/14/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
https://www.homedepot.com/p/Gas-One-RV-P........wTBZirjniOvOrBoCaH4QAvD_BwE&gclsrc=aw.ds
This is the type crimp you want.
https://www.amazon.com/Camco-Connector-R........=9027230&hvtargid=pla-450116384824&psc=1
This is the type you do NOT want
enblethen
Moses Lake, WA
Posted: 02/14/21 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
The pigtails from tank to regulator is high pressure , bubbles would be larger and easier to find.
Regulator vent and the flexible pipe from regulator to the black iron pipe is very low pressure. Bubbles would be very small.
In ancient days, we used White ivory bar soap for making solution.
1320Fastback
Vista, Ca
Posted: 02/14/21 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
The new trailer we had had a brass fitting above the tires fracture and leak out two full bottles as we drove from Flagstaff to Needles.
Our current trailer this last month had a propane smell inside as we were prepping it for a desert trip. I sprayed all the fittings underneath remembering our last problem but found nothing. Letting it air out and then immediately returning inside with my sniffer I located a strong smell at the heater underneath the stove. Pulling the grate off and spraying the exposed fitting created bubbles, lots of them. I got some wrenches and loosend the fitting then snugged it back down. No more leak and the big propane bottles up front remained full after 5 days in the dunes using the heater every night.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
