RV.Net Open Roads Forum: Truck Campers: Covering a truck camper AFTER a snow?
 > Covering a truck camper AFTER a snow?
AlaskaDude
Fairbanks, Alaska
Posted: 02/12/21 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
We recently (about 2 weeks ago) bought a 2017 Adventurer 86FB truck camper that was uncovered here in Alaska. It had about 4 inches of snow on it, and we've since brushed all the snow off (as much as we can at least), and have purchased a camper cover. My question is this - is it a bad idea to cover it for the rest of the winter? It's consistently between 50 below zero and 20 above zero right now; never above freezing. I only ask because when the thaw does finally occur, I feel having it covered will keep moisture in. Any thoughts on this?
Thank you in advance!
billtex
RI
Posted: 02/12/21 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Kind of had same situation here. New cover arrived late, after first snow. I covered it. These things are made to be outdoors so shouldn’t hurt anything. I am pretty sure that initial snow has melted under the cover from sun light and just run off. Cover will keep any new snow off going forward.
Not best situation, but what are you going to do?!
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
jaycocreek
Idaho
Posted: 02/12/21 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed,I just shoveled my TC roof today for the second time in a little over a week..If I was too put my cover on,I would do the best I could at removing the snow first then put it on..Won't hurt a thing..
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/Engel compressor fridge/3 gr 27 batteries/Honda 2k/Honda 3K/WH Camo 2250/Reese solid bar extension/Buddy heater/3 inverters//Happi Jack tie downs /Firestone bags/Yamaha Rhino/Winch and Lockers
JimK-NY
NY
Posted: 02/12/21 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Snow under the cover? Why use the cover at all?
AlaskaDude
Fairbanks, Alaska
Posted: 02/12/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you guys! I’ll just make sure it’s fully brushed off and put the cover on. I appreciate the advice.
AlaskaDude
Fairbanks, Alaska
Posted: 02/12/21 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Minimal snow... just what I can’t brush off. The reason I’d prefer to put the cover on still is because anticipate we’ll get at least another foot of snow this season.
Gary Morency
windsor ontario
Posted: 02/13/21 04:08am Link  |  Quote  |  Print  |  Notify Moderator
I would put it on then down the road when the weather gets warmer and sunny remove it and let the roof dry. Then throw it back on till you need the camper for a trip.
ticki2
NH
Posted: 02/13/21 05:22am Link  |  Quote  |  Print  |  Notify Moderator
If the temps are consistently below freezing I don’t see what harm any new snow will cause . I would not want to trap snow under the cover . What purpose at that point would the cover serve ?
'68 Avion C-11
'02 GMC DRW D/A flatbed
Bradymydog
Western MA
Posted: 02/13/21 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I purchased the best cover based upon reviews - gold something or other - it is not waterproof, it's only purpose is to keep the camper clean and avoid UV damage which it does well. I'd be more concerned about damaging the roof trying to remove the snow than any snow trapped between the roof and cover.
jaycocreek
Idaho
Posted: 02/13/21 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Exactly,do you know how many vents I have replaced in the last 5 years from damage removing snow...Answer...To many...The small amount of snow on the roof when covered will cause no harm...A good cover is heavily vented and the snow will melt without causing harm..Snow that has been up there thawed then frozen again Is hard to remove making damage removing it more probable..
I shoveled mine yesterday then broomed it and there's still snow up there in hard to get areas,I wouldn't hesitate to put a cover on it now except I'm going to use the TC shortly..
