RV.Net Open Roads Forum: Truck Campers: Chassis Ground on a Bigfoot truck camper????
 > Chassis Ground on a Bigfoot truck camper????
GULFMAN
MOORESVILLE, NC,USA
Posted: 02/13/21 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Hello all!!
I am trying to wire in a Victron BMV 712 battery monitor.
The instructions say after relocating all existing negative wires to the load side of the shunt to run a new (thick) wire to chassis ground. Would a truck camper have a chassis ground and if so what would it be. Note I do have a Green wire from some that is clamped to the propane line in the back of the refrigerator access cover..
if someone could help me out I greatly appreciate it.
Thanks ??
TxGearhead
Posted: 02/13/21 07:03am Link  |  Quote  |  Print  |  Notify Moderator
I've got 2 or 3 grounds bolted to the camper tie down ring on the front drivers side. I assume they would ground through the tiedowns to the truck frame. I am the 2nd owner but I'm pretty sure it came from the factory like that.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
deltabravo
Spokane, WA
Posted: 02/13/21 07:05am Link  |  Quote  |  Print  |  Notify Moderator
GULFMAN wrote:
Hello all!!
Sounds like the same question posted to one of my videos,
Here's my answer / explanation:
From an "electrical" standpoint, there isn't a chassis ground that acts as a current carrying conductor on a truck camper. There is a "safety ground" as you have found on the propane line. There's probably also a ground wire from the negative bus of the DC panel and the AC panel to the same "ground" point where the propane line is grounded. Ignore all of that.
A simpler way of describing the connections with the shunt and the battery bank is this:
Take all the wires off the battery negative that feed to the camper, connect them to the "load" side of the shunt. Take a new wire/cable and run it from the battery side of the shunt to the negative battery terminal.
There should only be one cable at the negative post of the battery - the cable that goes to the battery side of the shunt.
In a multi-battery system you'd also have a cable from one battery to the next.
The main key here is that everything that "was" connected to the B- (other than a battery interconnect cable in a multi battery system) is moved to the load (ground) side of the shunt and then a new cable is installed from the battery side of the shunt to the B- of your battery bank.
* This post was edited 02/13/21 07:20am by deltabravo *
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
deltabravo
Spokane, WA
Posted: 02/13/21 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Back in the 90s I worked for Heart Interface. We had 4 different amp hour meters - very similar to the BMV-712.
I wrote a lot of tech documents about installing them. I also was on the phone all day helping people with questions on inverters / amp hour meter installation.
I always remember the "chassis ground" aspect of the installation instructions throwing everyone for a loop, because they had no idea where the "chassis ground" was, hence the reason I described it like I did above with regard to "there only being ONE cable on the battery negative post, and that cable goes to the shunt"
Once you have accomplished that, from a "chassis grounding standpoint", you're bases are covered, because essentially everything is connected the same as before, it's just that you now have a shunt inline.
deltabravo
Spokane, WA
Posted: 02/13/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Here's the video: BMV-712 in my AF 811
deltabravo
Spokane, WA
Posted: 02/13/21 07:24am Link  |  Quote  |  Print  |  Notify Moderator
I took the BMV-712 out of my AF 811 and am working on installing it in my 992.
In this video I talk about the shunt and the associated wiring to it.
bigfootford
Fair Oaks, California
Posted: 02/13/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
That ground is for grounding the camper to earth when the jack foot is touching the ground.
My 2000 BF's main grounding point for the battery negative and AC ground is attached to the propane copper tubing that is located under the bed step, where the converter is.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Mich 245/70XDS2's, Bilstein shocks, air bags/pump, EU2000, PD 9260,Lifeline 100ah, 200W. solar, Morningstar Sunsaver 15A/ display panel, Trimetric, Delorme/laptop, Holux gps rec,led lights, Wave-3 heat.
GULFMAN
MOORESVILLE, NC,USA
Posted: 02/13/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the reply’s!!!!
All I am trying to do is a have a real basic solar charging system.
I have installed 2 Battle Born 100 amp hour batteries
Added 300 watts of Zamp Solar
VICTON charge controller and shunt
Replaced my original factor converter with a Progressive dynamics lithium replacement
and that’s it . I have a Honda 2000 generator for everything else..
I would have liked to had a more robust system but this was Challenging enough for this 69 year old mind. I would like to give a big thank you to Delta bravo for his help through YouTube comments and his rv.net comments. If you all would like to watch some very Intuitive videos go to Delta bravo YouTube channel. This man’s knowledge on RVs inside and out is amazing.
Thank you again!!!! ( RV. Net and all its followers are awesome)
Gary
noteven
Turtle Island
Posted: 02/14/21 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Just subscribed to Delta Bravo [emoticon]
Sounds like you have a nice setup going there Gulfman
Bradymydog
Western MA
Posted: 02/14/21 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
I was also wondering about the chassis ground. I am getting all my components together now for my bigfoot TC. (2) BB Li batteries, Victron BMV 712, Victron Multiplus 12 2000 80/50 converter/charger. For charging from the truck, Victron Orion TR Smart 12/12/30 DC to DC charger. Solar charging to be added later this summer. I do have a question as to where to attach the case ground(s) - for the new inverter charger for example.
