Ed_Gee
Central Oregon coast
2oldman wrote: wopachop wrote: Dang a combined black and grey tank?? You should be able to confirm that next time the shower water overflows the drain. Yuck. Are they building them that cheaply now? I sure see a lot of newer "lite" rigs with weird stuff.
Note: the OP's camper is a 2007 year model.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
2oldman
NM
Ed_Gee wrote: Note: the OP's camper is a 2007 year model. Oops. thanks
opnspaces
San Diego Ca
Dusty Boots wrote: Yes, this is the manual I have. Black water not overflowing into the shower drain when full. Must have a flapper valve in-between to separate the 2 tanks. When I get home I will flush and empty the Black water tank, open the cap and valve. Fresh water into sink should flow out w/o backing up???
Leave the drain hose connected so you don't wind up with a mess. Just pick up the hose in the middle and you'll feel it filling up with water and getting heavy. Then just set the hose down and let it drain out into the sewer.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Dusty Boots
six pac
Yes thanks, the locking access door to the hook-up is really small, just fits the bayonet end of the hose and my hand to attach up, really a lame design. I have already modified plenty inside, maybe I should cut a bigger access door. Still no posts whether I have 1 or 2 tanks. Anyone know?
ticki2
NH
Dusty Boots wrote: Thanks for the recommendation, information about the grey water waste is not in my owners manual or the single valve operation procedure. Just states 2 - 38 gal holding tanks. The electronic g/w tank indicator may be faulty but, the tank does not seem to have the 38 gal capacity as indicated. (floor drain in shower overflows)
From the manual you do have 2 tanks . One is black/gray waste tank , the second is the fresh water tank . You don’t have separate black and gray tanks .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Dusty Boots
six pac
Manufacturer: Six-Pac Campers;
Freshwater capacity: 40 gal
Std. window covering(s): Pleated shades
Gray-water capacity: 38 gal
Stove: 2 burners
Waste-water capacity: 38 gal
Oven: N/A
Water-heater capacity: Std 6
This description makes it sound like Grey and Black are separate.
AnEv942
CA
A lot of sites list the Sixpac grey and black tank capacities as 38 gallon for each-however its the same tank.
Why there is a separate monitor for 2 waste tanks puzzling-unless they are measuring also same tank, one stuck? Cant imagine though 2 sets of sensors (what usually fouls) on same tank. Could mark, switch leads on monitor see if it changes, if it doesnt change monitor suspect, if it does change not sure what that would tell, your still at square 1.
If there was some kind of one way valve on grey line it could be stuck- but capacity would be severely limited as only be between in pipe?
Never heard of one, sounds like a good idea.
But simplest, Id also empty tank, pour measured amount down grey see if it comes out.
edited 02/13/21 04:10pm by AnEv942 *
Our camper projects page
Kayteg1
California > Nevada
If there is TC who can have total of 116 gallons tanks capacity, I sure would love to see pictures.
32 Chev
Sandpoint, Idaho
my Okanagan 116 ULT has a 63 gallon fresh water tank an a45 gallon grey water tank and a separate 45 gallon black water tank for a total of 153 gallons plus the hot water tank.
2007 dodge Ram 3500 Drw 6.7 Cummins,6 speed auto, exhaust brake, Okanagan 116,Air, Onan genset, accumulator tank, fastguns, too much fun stuff.
Kayteg1 wrote: If there is TC who can have total of 116 gallons tanks capacity, I sure would love to see pictures. My little AF 860 has 111gal combined.
What are you talking about anyway?
