Jay Pat
Round Rock, TX
About a year ago, I needed the black tank dump valve replaced.
Found a mobile mechanic that would do the work.
He said his rate would depend on how "dirty" he got and gave the price range. He could not come out for several days.
I had the "rotary spray nozzle" that had been plugged up for several years.
The RV at that time had a straight shot down thru the toilet to the tank.
I had the wand that one sticks down thru the toilet. Just hadn't used it in a few years.
So, I flushed and flushed with the trailer tongue as high as I could get it and as low as I could get it.
I had crystal clear water coming out of the black tank.
So, I filled the tank up one more time.
When the mobile mechanic showed up, I dumped the one last time and he was very happy to see clear water in the line.
There was still a mild odor in the tank.
To wrap things up, that wand puts out a lot of pressure and easily reaches the roof, sides and all 4 corners of the black tank. I doubt the rotary rinse can compare.
I do add product that does help with the smell.
2010 Ford F-350 SRW
2021 Grand Design Reflection 315
pigman1
Delaware
When we dump we use the factory installed flush line to add water to the tank until there are no significant pieces of "stuff" seen exiting in a clear pipe section. That's it. We add NO CHEMICALS OR ANYTHING ELSE to the tank. . . ever. We boondock often as well as keep the Bus in full service campgrounds for portions of the year. When at home the Bus is stored in a fully enclosed building and we have never had any odor problems. We have over 110,000 miles on the Bus and it is over 8 years old.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
ken56
Tennessee
Some people will use a bleach solution to help keep bacteria from producing "that' odor. I don't but I do rinse very well when I wont be using it for a few weeks. Heat and bacteria are friends and it will produce sewer stench and in a closed trailer that isn't used for even a few weeks can get stunk up quick. No need to sanitize in my opinion, just rinse well.
dedmiston
The West
Once you use the tank, it will never be sanitary again.
There are lots of opinions about maintaining the tank (I flush it out and refill with a few gallons of water plus Dawn and Calgon), but I doubt you'll ever find a consensus.
In any case, there's no way to sanitize it.
Toys:
- 18 Can Am Maverick x3
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
TechWriter
On The Road
I don't sanitize, but I'll dump some bleach in both black & gray tanks before I put my RV in storage.
2001 Newmar Mountain Aire 4095 DP
Part Timer 2004 - 2013
Full Timer 2013 - 2020
Part Timing Again
www.rvSeniorMoments.com
DISH TV for RVs
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Sanitize the black tank??? What are you planning to do, haul drinking water in it? That's like asking people who are on their own septic tanks is they sanitize them.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Boon Docker
Trackrig wrote: Sanitize the black tank??? What are you planning to do, haul drinking water in it? That's like asking people who are on their own septic tanks is they sanitize them.
Bill
For sure, you can never have enough drinking water. What, you never sanitize you septic tank, shame on you.
bucky
Raleigh metro
EV2 wrote: Let’s be fair. Our entire life we have heard about people who’s poo does not stink. They have an image to uphold.??
Love it, that's awesome!
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Wherever I happen to park
"That odor" is more likely NOT the black tank. (Gray or the park septic cause you left a valve open)
The only reason to sanitize the black system is if you are going to be doing repair work on it. and I'd let the pro who does the repair do the sanitizing as well
Home is where I park it.
Boomerweps
Hills of PA
This question brings to mind the people who think they can pick up a turd by the clean end!
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
