RV.Net Open Roads Forum: Fifth-Wheels: Heated hose
 > Heated hose
buc1980
houston tx
Posted: 02/13/21 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
What brand of heated hose you use.By the reviews none are very good leak or froze.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
pianotuna
Regina, SK, Canada
Posted: 02/13/21 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
If it is truly cold, then use the on board water tank.
Currently -31 c (-24 f)
Regards, Don
Owens River Road area, north of Mammoth
Posted: 02/13/21 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
The safer way is as stated by pianotuna.
RichB3125
Beavercreek, OH
Posted: 02/13/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
x2.
Many parks don’t allow them. If you are going to use one, make sure the pipe and faucet are protected.
ssthrd
Vancouver Island
Posted: 02/13/21 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have used a Camco in temps to -22C (about -8F) with no issues with the hose. However, the water did freeze just inside the TT wall.
I had my fresh water tank full, so we used it until the temp moderated. Less worry.
2014 Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Anderson
DeeBee, JayBee, and Jed the Black Lab
md_procouple
Parkville, Md.
Posted: 02/14/21 05:07am Link  |  Quote  |  Print  |  Notify Moderator
We just use a regular hose... Hubby uses "Heat Strip / Tape" then covers it with foam pipe insulation. Our neighbor uses hollow pool noodles as insulation. Happy Camping !!
Vickie, Me, and "Scruffy" our dog make THREE
JIMNLIN
Oklahoma
Posted: 02/14/21 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I made my own with the regular hose for water 10' long. A simple google shows how its done.
My 110v heat tape had a thermostat.....a very thick noodle.....wrapped with several more layers of rolled insulation.....a layer of visqueen for keeping water out.... final wrapped with duct tape so its sheds water.
No problems all winter with it laying on the ground with -3 degree temps and 38-40mph winds.
This was 22 years ago and store bought heated hoses wasn't much back then. Much depends on winter where you will be.
handsome51
Baytown
Posted: 02/14/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
We had a rally one year in Bandera, Tx and it was 15 degrees at night. All I did was slightly run the cold water facet in the kitchen sink. Like I do at home when it freezes. Did not need to run the hot since it is in the RV. That kept the water hose from freezing at night. While some people would unhook there hose at night and roll it up and put it out in the day again. I found that to be a pain in the ass. I liked just slightly run the cold water side of the kitchen faucet.
SDcampowneroperator
South Dakota
Posted: 02/14/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Handsome51, do tou know what risk you take trickling the water? Your sewer hose freezes ,backs up fills the grey then you wake to a flooded rig. Get by through a brief cold snap in the teens, but down in the singles and below the sewer hose will freeze solid.
I have seen flooded rigs several times because of a frozen sewer hose
What of the water wasted? A trickle of 1/2gal/ min X 10 hrs is 300gal. Hows the camp septic system going to handle that?
Just use your onboard tank, no worries, no waste.
Max, ex camp owner where, it gets cold
topjimmy
Washington Coast
Posted: 02/15/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
YEP thats is a fact BE careful doing that for one or two nights fine other than that nope...how wold I know that???[emoticon]
2015 Montana 3735MK Legacy,2007 3500HD GMC Dually LBZ Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
 > Heated hose
