RV.Net Open Roads Forum: Fifth-Wheels: Heated hose
 > Heated hose
pianotuna
Regina, SK, Canada
Posted: 02/15/21 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
handsome51 wrote:
I found that to be a pain in the ass. I liked just slightly run the cold water side of the kitchen faucet.
If you want pain--wait until the 3 inch sewer hose freezes. Then you will have tremendous fun trying to thaw it.
Having a heat wave today--it is only -5 F. (plenty cold enough to freeze a sewer hose).
Regards, Don
TXiceman
Full Time RVer
Posted: 02/15/21 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Solution is to drain both tanks, close the valves and then make sure the sewer hose is drained. Wait until it is warm enough and drain as needed.
Amateur Radio Operator.
pianotuna
Regina, SK, Canada
Posted: 02/15/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
TXiceman,
I've boondocked at -37 c (-34 f). I did not feel the need to drain my tanks.
SDcampowneroperator
South Dakota
Posted: 02/15/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
TXiceman,
Think he means waste tanks. I also heat traced my waste tanks and valves so they wouldnt freeze so I could 100 gal. batch dump as needed. A camp we wintered over in Whitecourt, Ab. had shallow sewer lines,( only 4') so they could freeze up underground if water did not rush through in a batch.
It isnt just the 3" slinky, it could be underground.
Saw that in another camp ( No. Dak.) where the oil workers had also heat traced and insulated their slinkys. The slow trickle of water through the underground pipes froze solid, then the sewage flowed out on top of the ground.
pianotuna
Regina, SK, Canada
Posted: 02/15/21 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hi SDcampowneroperator,
King's Acres in Regina, Sk has a few "plumbed in place" long term campers. I don't know how they manage to keep the lines unfrozen. It must be a real chore.
They have a dumpsite which is a "direct drop". So far it has always worked. I do admit that I tried to reduce my waste by washing dishes (approved by the management) in the laundry room--and using the toilets and showers that they provided.
This is the only thing I don't miss now that I'm no longer full time.
My waste tanks are enclosed but some one at the factory goofed so there is no heat. I solved that by installing a 600 watt fan based heater and a mechanical thermostat. It cuts in at 41 f. It didn't run a lot and while traveling I would power it from the inverter.
cpaulsen
Oregon
Posted: 02/16/21 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Have been using Campco heated for years with never a problem
cpaulsen
TXiceman
Full Time RVer
Posted: 02/16/21 06:19am Link  |  Quote  |  Print  |  Notify Moderator
We are north of Houston during this horrible weather. One of our idiot neighbors with a heated hose totally missed on the common sense. He has his heated hose on and plugged in. He carefully wrapped the faucet with an old towel and taped it in place. Problem is there is about 30" of exposed PVC pipe coming up from the ground that he totally ignored and did not insulate or heat trace. Guess what?....that pipe froze and he complains that the heated hose does not work.
Ken
JRscooby
Indepmo
Posted: 02/16/21 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Ken
Many don't understand how a frost proof hydrant works. The actual valve is below frost line. When water is shut off at that valve, it also drains the part above. When a hose is hooked up, vacuum will not let the water drain. The fact the hose is heated does not change anything.
If RVers had to dig in their pockets for damage, digging up that hydrant to replace, most would hook up hose, fill tank, then disconnect hose.
buc1980
houston tx
Posted: 02/16/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Heated hose or not if the campground shut down the water and the water pump don't work is terrible.Today is the third day in this situation.Happy camping.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
 > Heated hose
