RV.Net Open Roads Forum: General RVing Issues: Lippert Floe Water Drain Down System???
 > Lippert Floe Water Drain Down System???
bowler1
Rising Sun, MD
Posted: 02/14/21 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone have one of these? I am thinking of getting one. Seems like it would be conventient and useful. Seems like a good idea, but I did read a couple of negative reviews stating that the quality was low and that it was really loud.
Anyone have one of these / have experience with one they would be willing to shrare?
thanks
matt
Posted: 02/15/21 04:21am Link  |  Quote  |  Print  |  Notify Moderator
Seems a bit pricy to me... I used a portable air compressor that also came in handy for inflating tires and such (6 gallon pancake design 150 PSI) a regulator (50 psi) and an 8 buck (i think) or cheaper adapter plug. That compressor saved a few trips when I needed to air up a tire or two.
bowler1
Rising Sun, MD
Posted: 02/15/21 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Well it is pricey but I found a good deal on one. I already have a compressor but found that it is a bit of a PIA with a single person to run in and out of the camper. Having a unit that you can turn on and that is totally integrated would be nice. Just turn on the unit and go faucet to faucet. Just not sure about the quality and how well it actually works.
Gdetrailer
PA
Posted: 02/15/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Looks like a extremely expensive $250 air compressor in a plastic box you can hand on the wall and permanently plumb in..
You do realize that you can go to Harbor Freight and buy one of these..
For $10 and plumb it in with a "Tee" and shut off valve, for safety can add in a pressure switch to turn it off at 40-50 PSI for $30
The Lippert system also seemed to have a lot of complaints that it as very loud..
You can buy at HF a very quiet 120V air compressor meant for airbrushing that is very quiet, has built in pressure switch also for automatic operation..
$89.. they used to sell just the compressor but now it includes air brush stuff, just discard or give away the air brush..
I am not sure why you find you need multiple people to go in out of your RV to winterize..
I must be doing something wrong as I am the only one winterizing my RV..
I have used a portable "pancake" air compressor and I just use the simple "blowout" plug available anywhere and adapted that to standard air quick connects.
I also can just layout some hose from my garage compressor..
Drop regulator pressure to under 50 PSI and open the first faucet in line and close when only air comes out and then to tub and bath sink and then final is toilet..
Then open the water line drains..
Process only requires one person (me) and less than 15 minutes of time..
bob213
Fresno, CA
Posted: 02/15/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Just use any compressor(non-oiler) and one of these:
adapter
PawPaw_n_Gram
On the Road Somewhere
Posted: 02/15/21 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
An expensive potentially error prone system, looking to fix a problem that does not really exists.
And I bet a cold beverage of your choice we will see this advertised as a 'necessary accessory' on RVs before next winter.
Full-Time 2014 - ????
“Not all who wander are lost.”
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
wanderingbob
monticeeo, fla
Posted: 02/16/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Paw Paw , A solution for a problem that is more problem than the supposed problem !
MT BOB
Montana
Posted: 03/02/21 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Guess I am spoiled.My 91 S&S TC is "self draining",if sitting level.
CavemanCharlie
Storden,MN
Posted: 03/04/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
X3 for me.
I am just a weekend camper so I admit I use my water system a lot and the water doesn't set in the lines much. But, I blow my lines once a year when I winterize. The rest of the time they are full, the fresh water tanks it full, and I am ready to go on a moments notice.
