RV.Net Open Roads Forum: Beginning RVing: surge protector and water filters
 > surge protector and water filters
wiskeyVI
All Over
Posted: 02/17/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
When we bought our first RV, it had a clog in an elbow of an inside pipe right after we bought it.
After that, I never allowed water into the rig without at least a sediment filter.
When we got out of RVing, i was to the point that I had a complete home made system built into a milk crate that filtered everything, included a pressure regulator and could have been set outside or plumbed into the storage bay when cold or very hot out. It eventually morphed into a manifold system in our 5ver bay....
As for surge protection, I don't recall using one, but do intend to on the future.
I used standard household filters.
IAMICHABOD
Sunny So Cal
Posted: 02/17/21 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have to go along with many others and recommend the Progressive EMS,I know that it has served me well but I went with the Hard Wired one less thing to hook up and store later.
As for the company they get very high praise from me,I had a failure of the remote desplay unit and after talking to a real live person and going thru all the test procedures he said it was toast. They sent me a new one OVERNITE FEDEX I received it the next day.
As for the water filter I had problems with the Blue Camco ones,poor MFG as they always leaked,I went with Aqua Quest about same price but for me it was of a better quality.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
CampingCompanions
New York
Posted: 02/17/21 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 30 Amp surge protector by Progressive Industries. It was a pricier model because it was recommended to us by our dealer. WE figure with the amount of money we spent on the camper, we may as well protect our investment with a better quality surge protector. Hughes Watchdog seems to be a very popular choice as well. Good luck.
As for the water filter, we get the Camco TastePure water filter with flexible hose on Amazon. Last time I bought them, I got a 2 pack for $25.00.
philh
Belleville MI
Posted: 02/21/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Blue water filters are as useless as a colander.
I went with a clear household 5u filter and only run off internal tank, even with full hookup. I'm amazed at how much junk the filter traps.
pianotuna
Regina, SK, Canada
Posted: 02/21/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Do you put it before the pump or on the output side?
Regards, Don
campigloo
Baton Rouge, La
Posted: 02/21/21 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
I had what was supposed to be the top of the line Progressive ems. It shut down several times when it detected low voltage, like it was supposed to do. On the one power surge that I’m aware of, I didn’t know there was a problem until I smelled melting wire insulation. My next one will be a Hughes.
afidel
Cleveland
Posted: 02/22/21 12:26am Link  |  Quote  |  Print  |  Notify Moderator
The Camco water filters have worked great for us across parks in 43 states so far. Very occasionally there will be a sulferous taste that survives the filtration so we break out the Britta pitcher which has worked 100%. Total investment across 5 years and hundreds of nights, $75 or so.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
philh
Belleville MI
Posted: 02/24/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
it filters the water before going into the onboard tank.
4x4van
California
Posted: 03/09/21 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
I've been RVing for 30+ years; 1/2 boondocking and 1/2 in FHU campgrounds. Never use a water filter, but I normally fill from home from a good known municipal source. Occasionally, I will use campground water if I run out, but not often. And yes, we use our onboard tank for drinking, cooking, and bathing.
As for surge protection; I have the Progressive EMS unit bookmarked on Amazon, but again, I've never had/used one. I check voltage before plugging in, and I have a digital monitor inside that I can keep an eye on as well. Yes, I know that one "problem" and the Progressive unit would pay for itself, but I have yet to have any issues; knock on wood[emoticon]
* This post was edited 03/10/21 08:17am by 4x4van *
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 TriZinger, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
philh
Belleville MI
Posted: 03/09/21 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
As to surge, if the RV has a 50 amp service they are important. They are less critical for a 30 amp service--but you MUST check voltage under load before plugging in. If you are NOT prepared to do so, then get protection.
why would electronics be safer on 30a than 50a
