RV.Net Open Roads Forum: Truck Campers: Tires and Wheels
 > Tires and Wheels
Page of 5
Bradymydog
Western MA
Posted: 02/16/21 04:27am Link  |  Quote  |  Print  |  Notify Moderator
LR refers to Load Range Index 129 E 4080
otrfun
On The Road
Posted: 02/16/21 05:18am Link  |  Quote  |  Print  |  Notify Moderator
We replaced our OEM 275/70/18’s (3640 lb. rating) with Michelin Defender LTX 295/70/18’s (4080 lb. rating). Nice to have that extra 880 lb. rear axle tire capacity. Speedo is approx. 2 mph slower. There is some sidewall flex. Otherwise, a good tire.
JimK-NY
NY
Posted: 02/16/21 06:24am Link  |  Quote  |  Print  |  Notify Moderator
My Ram has 20" rims and stock 285 60 20 tires. The original Firestones are wearing quickly so I will probably need to replace them after my next big trip. I am thinking of Michelin Agilis tires. Load E is rated for 3640#. What choice do I have for a higher load rated tire in that size? Is there a bigger size that will fit my rims?
Posted: 02/16/21 07:11am Link  |  Quote  |  Print  |  Notify Moderator
I ran 275-65-20s on our old truck. A hair taller than the 285-60 and 3750 lb load rating.
Generally higher load rating in similar width and rim size is higher aspect ratio.
Same truck, hauled AF860 on OE 285-60-20 and 295-70-17. Can’t say I noticed any difference.
2017 Heartland Torque T29
otrfun
On The Road
Posted: 02/16/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
The only 20", 4080 lb. rated tire I'm aware of is the 295/65/20. Unfortunately, this tire has a 35.1" diameter (285/60/20 is 33.4"). FWIW, a 285/65/20 has a 3860 lb. rating with a 34.6" diameter.
BTW, the character based Load "E" rating is a rough, general tire category based on the number of plies, air pressure, etc. The "numerical" load rating (125, 129, etc.), along with a conversion chart, provides you with the exact number of lbs. the tire is capable of supporting.
JimK-NY
NY
Posted: 02/16/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
The tires I have are 285/60/20 with a load rating of LT125, 3640#. The 295/65/20 tires would be too large with too much of a change in the speedometer and gearing. It sounds like the 285/65/20 tires would work and they do have a 127, 3860# load rating.
ramcamper
S. Calif
Posted: 02/16/21 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
My BFG KO2's just came in and my tire company told me to come down and have them put on but I've decided over the last 2 days that the KO2's had too many reviews with horrible wear on them with trucks. So, I've done more research and decided on the Toyo LT 295/65R20 129 4080lb for my 2018 3500 Ram. I like dirt roads getting me to places nobody else is so want and need the A/T tires. Lots of good reviews for this tire plus my brother in law has them on his 2500 Silverado towing a 32ft 5th wheel and his Jeep..... and loves the tires. Right now, the tire shop is seeing if they're available in Calif. because there's none in the warehouse.
AISURFFISH
BERLIN MARYLAND
Posted: 02/16/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
You would have better luck asking which oil should I used..lol
Just sayin..
Let the good times roll.
I just bought new nitto terra grappler g2.. almost 4000lbs per tire ..bad ass for a stock rim.
2017 F350 6.2L Crew Cab
Arctic Fox 990 2021 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
Slymer
Ontario, Canada
Posted: 02/18/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
I went with the Visions for our F350 SRW. That was to allow me to go to commercial tires as I felt the rubber would be the weakest link. I went with Michelin XDS2's. 16 ply with load range H. Camper on, I run them at 120 PSI. Camper off I run them at 80. Supposed to be good for 100,000 kms. and so far it looks like they just may. I got drive treads for the rear but steer treads for the front (quieter up front). I also upgraded the TPMS valves at $35 each but they have never worked. The truck won't recognize them. Every time I ramp up to 120 psi I get a dashboard message,..."low tire pressure". Go figure. I just feel much safer with these tires.
Green Goblin
Minneapolis
Posted: 02/18/21 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I just added Wrangler All-Terrain Adventure with Kevlar to my F250 Superduty, they are fantastic in snow and ice, a very comfortable ride and very quiet.They are fantastic in snow and ice, a very comfortable ride and very Tested them out in the MN ice and snow and bitter cold temps. I am extremely pleased with the purchase.
Page of 5
 > Tires and Wheels
