Stickboy
North Carolina
The large driver's side slide-out occasionally creeps out 1/2" to 1" when driving and/or setting in driveway. It usually take about 12 hour, and seems to mostly be the lower edge, and on both front and rear ends of the slide-out equally.
Before I start driving I bring the slide-out completely in and inspect it visually to make sure that it is closed. New to the RV world and any help would be Great.
Also every since this started the slide-out will extend but will not retract without jacking up the outer edge of the slide.
edited 02/16/21 02:36pm by Stickboy *
MountainAir05
New Mexico
do you know the model of your system. Is it electric or hydraulic.
Stickboy
North Carolina
Yes, HWH Hydraulic system with a Dewalt pump.
MountainAir05
New Mexico
https://www.forestriverforums.com/forums/attachment.php?attachmentid=9296&d=1321739509
https://www.forestriverforums.com/forums/attachment.php?attachmentid=9295&d=1321739509
If this does not work send me a email to justforyu@msn.com and will send them that way. One is for the level system and the other one for your slide. Probable just a leaking valve, but would need to know which system you have and it has pictures so easy for you to pick.
Stickboy
North Carolina
Thanks for the INFO!!
Stickboy
North Carolina
That is the correct system, it is a typical Dewalt slide-out system.
It utilizes a cable and pulley
system to synchronize the room as it
travels in and out. It is a non flush floor type.
