RV.Net Open Roads Forum: Truck Campers: Solar with Lithium Battery
 > Solar with Lithium Battery
Page of 5
2Noob4U
Pueblo
Posted: 02/16/21 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
I will be purchasing a Battle Born lithium battery in a month or so. My truck camper came with a solar charge controller, inverter and I can simply drop the new battery in place of the lead acid one by flipping a din switch and changing the settings on my charge controller from flooded to lithium.
My question is I have one 100 watt solar panel. What is the charge rate like? I have a portable 2000 watt generator that works great, but it would be even better to leave it behind.
3 tons
NV.
Posted: 02/16/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
For estimation purposes, I would assume about 5 amps of solar harvest where conditions are ideal,
but the nice thing about LFP is that it has a higher charge receptivity rate (compared to wet cell) due to low internal resistance...This means that you’ll get better results with just your one panel, though solar is so inexpensive nowadays (often only about 0.85 cents per watt) I’d recommend at least another panel - but if you do so, try to keep the panel voltages approximately the same, else the higher voltage panel will default to that of the lower one (first, confirm the amp capacity of your charge controller)...The other thing to consider with LFP (LiFePo4) is your factory converter-chargers output voltage...always feel free to PM me if needed.
3 tons
Sounds other thing is
pianotuna
Regina, SK, Canada
Posted: 02/16/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
In perfect solar conditions about 20 amp-hours per day.
Look at SiO2 and buy two batteries for the price of one Battleborn?
Regards, Don
time2roll
Posted: 02/16/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
100 watts.... as said is something but not much depending on your usage. Run the propane fridge controls, water pump and a few LED lights in the evening. Much more and you will be looking for an additional 100 to 300 watts solar. Especially when the sun is low in the sky. But if the 100 watts gets you through and you pull out with a low battery to charge on the way home that is fine too.
675w Solar pictures back up
bighatnohorse
Gig Harbor - Cave Creek
Posted: 02/17/21 07:27am Link  |  Quote  |  Print  |  Notify Moderator
At best, you might get 5 amps under ideal conditions with a single 100 watt solar panel.
Please scroll down this page to see typical specifications for a 100 watt solar panel: https://richsolar.com/collections/solar-panels/products/100-watt-solar-panel
Also note its voltage specification.
Another concern might be the campers shore power converter.
I see that the Progressive Dynamics 4000 series includes a switch to charge either lead acid or lithium batteries:
https://www.progressivedyn.com/rv/power-centers/inteli-power-4000-series/
Williams AZ area
Posted: 02/17/21 08:41am Link  |  Quote  |  Print  |  Notify Moderator
IMO 100 watts isn’t enough on sunny days much less in shade or on cloudy days.
3 tons
NV.
Posted: 02/17/21 08:47am Link  |  Quote  |  Print  |  Notify Moderator
The PD Lithium option just sets and holds the output voltage at constant voltage, constant current
14.4v which works well, but not advised for a storage scenario...Their ubiquitous 9245 (or 92xx series) will do the same thing by switching into the Boost mode via the optional Charge Wizard pendant...
3 tons
Posted: 02/17/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Does it really matter?
You’re dropping $1000 on a 100ah battery (presumably) and plan to sip power to the point that you can keep a single battery topped up with a single 100W panel?
First, if you only use what that little panel can replenish daily under normal conditions, you’re basically using no power.
What can you run on 80-85 watts for say 12 hours (being generous)?
Sounds like you’re confused and think a $1000 battery is a magic solution to free power.
It’s only a magic solution to making your wallet lighter, unless weight is that critical.
In which case, no, a 100W panel won’t keep up unless the battery is just there for looks and not use.
2017 Heartland Torque T29
Posted: 02/17/21 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Marketing help please.
If I wanted to make a battery that “everyone” would buy, what is a more catchy name than “ Battleborn”?
There are enough people enamored with that name and the magic they think it provides, surely I could make a bundle if I had an even better name or catch phrase!
Note, firepower and antigravity are already all used up, lol.
BFL13
Victoria, BC
Posted: 02/17/21 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, change your solar controller settings so it won't do more than 14.6v, and kill any temp comp for the same reason--nothing above 14.6v ever. No "equalize".
The sun won't shine any brighter by changing to LFP from your FLA so ignore all claims about "faster charging" with solar if only you swapped to LFP.
In the same way, a 55 amp converter will not do more than 55 amps either if you swap to LFP. Engage brain before believing the advertising! [emoticon]
You will get more usable AH but not twice as many. From a 100AH batt you will get 80 instead of 50 by following the guidelines for each type.
(20-100 vs 50-100)
Watch out for high temp limits on the LFP since you say Pueblo it might get hot there. Also low temp limits at night?
To go camping off-grid you need more than 100AH or be a tent camper, so that means you will need two of those very expensive LFPs, not just one. That also means your one batt now is not enough. Get your wallet out for a second one of whichever you choose.
A 100w panel will help a little but not much. 200w can do a useful day's work.
Now the good news! [emoticon] LFP works well with solar, because you don't have to get back to 100% SOC every day. Solar can kill FLAs for this reason, that the sun goes down before the batts get truly full, which eventually kills them from sulphation. No worries about that with LFPs (or SiO2 for that matter).
Also Battle Born is not the only pebble on the beach.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Page of 5
