RV.Net Open Roads Forum: Very new to living in an RV/Trailer
 > Very new to living in an RV/Trailer
ronharmless
The far side
Posted: 02/17/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Just my opinion and you can take it or leave it; but, unless you are given or already own a late model, high quality, 4 season RV, you are not going to save money living in a RV in a RV Park. It would be cheaper and better to rent an apartment or small house. If it was a mobile home, possibly (they are built to different standards than a RV).
Anza-Borrego Desert SP area
Posted: 02/17/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I agree with ron. Do the math carefully. You may be saving nothing with RV living in a campground vs. an apartment or single room. Heating the RV will be a challenge.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Posted: 02/17/21 09:56am Link  |  Quote  |  Print  |  Notify Moderator
What he said.
If you can’t afford an apartment in Kalamath Falls, you can’t afford a full time RV and campsite.
You also do not sound capable of what’s required to full time RV.
Sounds like your style of RVing will be more akin to downtown Portland.
I would suggest the best plan of action, find the most economical apartment or room for rent and concentrate your efforts on making more money and saving more money, not cluttering you the world with another junker RV that the taxpayers will ultimately pay to recycle on their dime and not yours.
2017 Heartland Torque T29
DrewE
Vermont
Posted: 02/17/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
A medium size flat screen TV is maybe 50 watts (unless it's a plasma screen--they're power hungry). A laptop is maybe 75 watts, though they vary a lot and the actual power consumption is quite dependent on how heavily loaded the CPU is and how bright the screen is. A PS4 is around 75-150 watts (modern consoles are pretty power hungry, relatively speaking). A phone charger is a few watts, and a cable modem not much more. All told, it sounds like your electronics are running maybe 200-250 watts, or a couple of amps. That's not at all likely to be the least bit problematic in any campground with hookups.
rexlion
Broken Arrow OK
Posted: 02/17/21 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Be prepared for high noise levels (RV furnaces and air conditioners) with drafty conditions in winter. RVs don't have many square feet, so opening the door lets out a huge percentage of the climate controlled air.
When you find out what RV parks charge, you may be shocked.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
Gdetrailer
PA
Posted: 02/17/21 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
YeeYeeHaircut wrote:
I don't exactly plan to get far out into nature, just a temporary home until I can save enough to get something else but live there for a while. I will definitley ask about it and see if I can find out with hookups like that in regards to the net - thank you.
YeeYee, I have to agree with Ron..
Folks often get on this forum with the notion they will save a lot of money by living in a RV in a park setting, paying for a lot. Parks with electric/sewer/water are not cheap rent.. Would not be too surprised that you will get prices well above $800-$1200 per month as many RV parks tend to charge $50-$100 night in season, some reduce the price out of season but I suspect you may be hard pressed to find one below $30 per night or $900..
You are not going to "save" money living in a RV, especially if you have to buy one, then pay the monthly lot rent..
Your profile states Oregon.. Your gonna get cold and wet, living in a RV in the winter time is going to eat you out what remaining money that you didn't have leftover from paying the lot rent..
Very few RVs are designed for "four season" use, they have little to almost zero insulation from the floor to the roof, single pane windows.. Your going to have to adapt to a completely different lifestyle that includes not heating to any roasting temps above 60F..
Even that temp will use 30 lbs of propane in only a few days, I would not be surprised if you use two 30lb cylinders in less than a week.. Depending on the current cost of propane that could be as much as $60 per week or $240 a month and you are only heating a couple of hundred square feet and freezing at the same time.. You might save some money by leasing 100 lb propane tanks but often they will want money upfront or you to buy them..
Something else to consider, many "parks" are seasonal in cold weather states, they CLOSE during the winter and for good reason, it is difficult to keep the water systems from freezing, costs a lot to install and run heat tapes in the winter.. If they don't close, they may turn off the water to the park except for a bathhouse.
For example, I did a search for RV parks in Klamath Oregon area..
Rocky Port..
HERE is only open Open Mar 15 - Nov 30..
Last Year's Rate was $37 to $46 per day..
HERE is a search which found 10 RV parks in your area..
Then you will have the holding tanks to deal with, unless it has insulated and heating pads on the holding tanks, freeze ups of the tanks is a real issue to deal with and not to mention YOU will have to dump even the toilet tank known as "blackwater"..
Do yourself a favor, find a small apartment, in the end, it will be cheaper and much nicer than attempting living in a RV during the winter.
bikendan
Camano Island, Wash.
Posted: 02/17/21 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, many are fooled by media and tv shows about RV fulltime living being cheaper than more traditional living choices. The reality is that rarely is it much cheaper.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
blaczero
Posted: 02/18/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the above about the cost. It isn't necessarily a whole lot cheaper to live in an RV. We do it for the freedom and adventure.
Anyway, the internet situation: I would get something like this
https://www.amazon.com/MOFI4500-4GXeLTE-SIM7-COMBO-Upgraded-Antenna-T-Mobile-Verizon/dp/B089NYWJYK
or
https://www.mobilemusthave.com/Pepwave-MAX-BR1-MINI-wLTE-Advance-Modem-GEN-2-Hardware-100MB-Support_p_16.html
You can just take a sim from your phone and put it in the MoFi (Pepwave is an option too, that's what I got) and share the internet connection as if your phone was creating the data.
Basically if you use your "hotspot" on your phone you'll be throttled and it'll generally be very slow. With the above device, it's not a hotspot so the data won't be throttled.
Do some research on it, there are a lot of RV'rs on youtube that cover these devices, plans and connection options.
