way2roll
Wilmington NC
howdy35 wrote: We are full time in our RV and the fresh water tank was being used in place of the supply hose which froze up. I was not aware the fresh water tank was not receiving enough heat since it is forward of the last heated bay from the steps to the generator.
Anyway, what is done is done and nothing can happen to repair/replace it until it gets warmer. Once it warms up, I can hook up the hose again and try to look at the damage.
My thanks to schlep1967 for the info on replacement tanks. I have started an insurance report and will await their help with the solution.
Just another hiccup. Arnold
Look on the bright side. Now you have a Chassis wash system.
howdy35
Athens, Texas
(way2roll) That's a good one. A bit of humor is good for the soul. Thanks for the post. Of all that could happen, we are Blessed
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
howdy35
Athens, Texas
An R V Tech came out and discovered there were two forty-five gallon tanks but only one was damaged so he pulled out the damaged tank and replumed the undamaged tank to supply water to the Bus. The damaged tank blew apart and split almost a third of the way down the top. Now I have one 45 gal of fresh water on board instead of 90. That should work fine.
edited 03/26/21 08:35pm by howdy35 *
RLS7201
2 1500 watt heaters would have probably boiled the water in the tank. The loud pop was probably steam pleasure relief.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
LouLawrence
Traveling the US!
As mentioned previously, this is likely NOT a fiberglass tank but rather a plastic tank and repairing these is nearly impossible. The good news is that an exact replacement should still be available but likely will require a special order.
Keep us up-to-date as the weather warms up and you are able to discover what blew, a tank or a water line. I am sure hoping it's a water line!
Ray,IN
IN, USA
This may be helpful to you and your ins. co.:
https://www.plastic-mart.com/category/34/rv-holding-tanks
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
