RV.Net Open Roads Forum: How to replace sofa in 5th wheel?
 > How to replace sofa in 5th wheel?
mileshuff
Phoenix, AZ.
Posted: 02/17/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Do most RV sleeper sofa's come apart somehow to get old one out and new on in? The sofa in my 2014 Winnebago 5'er apparently was ultra cheap bonded leather and vinyl. Peeling badly. Wanting to replace it or have it reupholstered.
Any recommendations of shops in Phoenix, AZ to do either?
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
PartyOf Five
Wheaton, IL
Posted: 02/17/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
The metal frame supporting the jack knife is very heavy but everything else is usually a bunch of parts rather than a single sofa assembly.
Upholstery shops are very pricey, and have lead time- but with some basic skills you can buy the material, use a staple gun, and give your coach a new look. Add foam based on desired firmness too.
Having a friend whose attention to detail it's better than yours is wise. :-)
PartyOf5 appreciating our Creator thru the created. 5 yrsL 50k, 49 states & 9 provinces.
May you find Peace in all you endeavor.
Mfan
Otsego,Mi
Posted: 02/17/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Everything comes apart. The question is do you want to put it together again?
Old-Biscuit
Verde Valley
replace it
old one is cheap/falling apart
so tear it apart---usually the back comes off and you can remove the inner bed frame
Measure space. measure doorway. measure new one and make sure it can be easily disassembled in order to get back in thru door
US NAVY------USS Decatur DDG31
Posted: 02/17/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Put some actual thought into it. I don’t know how to get your sofa out of your door.
What I can say though, is find one that you can get IN the door. You can always get the old one out. That’s what sawzalls are made for, worst case, although I bet they didn’t build the camper around the sofa although ICBW.
2017 Heartland Torque T29
Dick_B
Palos Heights, IL USA
Posted: 02/17/21 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Just slightly off topic but do you really need a sleeper sofa?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Seneca 35GS
whittier
Posted: 02/17/21 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
While visiting friends in Yuma, Az. and needing our RV Loveseat sofa re-upholstered we went to Yuma MarketPlace and got a quote from ACTIVE RV upholstery. Our sofa is a 60" wide Flexsteel sofa sleeper w/ kick-outs. Total cost for reupholstry was $950 in 2019. Price included remove and reinstall. It came out of the RV in pieces, yet upon reinstall it has worked better than new. They know how to make all the correct adjustments. Phone # (928)235-2780.
dedmiston
Coast to Coast
Posted: 02/17/21 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know if you're still trying to get yours out or not (and getting the new one in), but to get the most side-to-side space out of your doorway you'll need to disconnect the rod that stops the door from opening all the way. With that disconnected, you can open the door fully and get it out of the way.
Beyond that, it's just like moving furniture in your house: You have to turn things on their edges and rotate as you move through. There are some good videos on Youtube if you search for move a couch through a doorway.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Bumpyroad
Virginia
Posted: 02/17/21 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
when I see the ad on TV for a modular sofa etc. (Lovesack)??????????????? I wonder if that would be at all practical in a RV.
bumpy
mileshuff
Phoenix, AZ.
Posted: 02/17/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Used most trips.
