RV.Net Open Roads Forum: General RVing Issues: Occupied RV Fire
 > Occupied RV Fire
NamMedevac 70
Reno
Posted: 02/17/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
This poor lady just lost her Class A RV in a fire just now in Reno when a heater tipped over. She made it out safely but photo shows total distruction.
https://www.kolotv.com/2021/02/17/motorhome-destroyed-in-fire/
coolmom42
Middle Tennessee
Posted: 02/17/21 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
That's sad. And I doubt she has adequate insurance to replace it, even if she could replace it, and now she's homeless.
It must have been an older heater. All the space heaters I've seen in several years have a tip over switch that cuts them off when they fall over.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
TUCQUALA
Kennewick, WA
Posted: 02/17/21 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
If heater was a low priced coil or wire style, it still could have been pretty hot, and depending on what it was sitting on, could easily start a fire.
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
Cummins12V98
on the road
Posted: 02/17/21 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
" All the space heaters I've seen in several years have a tip over switch that cuts them off when they fall over."
Considering where most are made will you bet your life the tip over switch will work??? One BIG reason I had "Cheap Heat" installed.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Edd505
Elephant Butte, NM
Posted: 02/17/21 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
That was my first thought ................................
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
deltabravo
Spokane, WA
Posted: 02/17/21 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Article doesn't say if it was an electric heater or a propane heater. I can't imagine someone running an onboard genny to power an electric space heater (very inefficient use of resources) so it was probably a propane heater.
She's parked on the street, so it's highly unlikely she was plugged in.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
beemerphile1
Ohio
Posted: 02/17/21 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe this was the heater:
This stupid suggestion is all over Facebook the last couple of days.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
coolmom42
Middle Tennessee
Posted: 02/18/21 02:20am Link  |  Quote  |  Print  |  Notify Moderator
It's very easy to check the cutoff switch, and I always do that fairly often. All you have to do is pick up the heater, or tip it.
bucky
Raleigh metro
Posted: 02/18/21 03:45am Link  |  Quote  |  Print  |  Notify Moderator
fire clicky
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
bukhrn
Lanexa, Va
Posted: 02/18/21 06:57am Link  |  Quote  |  Print  |  Notify Moderator
X-2, I don't have to pick mine up very far,3/4" it shuts off.
2007 Forester 2941DS
2014 Ford Focus
 > Occupied RV Fire
