NamMedevac 70
Reno
This poor lady just lost her Class A RV in a fire just now in Reno when a heater tipped over. She made it out safely but photo shows total distruction.
https://www.kolotv.com/2021/02/17/motorhome-destroyed-in-fire/
coolmom42
Middle Tennessee
That's sad. And I doubt she has adequate insurance to replace it, even if she could replace it, and now she's homeless.
It must have been an older heater. All the space heaters I've seen in several years have a tip over switch that cuts them off when they fall over.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
TUCQUALA
Kennewick, WA
If heater was a low priced coil or wire style, it still could have been pretty hot, and depending on what it was sitting on, could easily start a fire.
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
Cummins12V98
on the road
" All the space heaters I've seen in several years have a tip over switch that cuts them off when they fall over."
Considering where most are made will you bet your life the tip over switch will work??? One BIG reason I had "Cheap Heat" installed.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Edd505
Elephant Butte, NM
coolmom42 wrote: That's sad. And I doubt she has adequate insurance to replace it, even if she could replace it, and now she's homeless.
That was my first thought ................................
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
deltabravo
Spokane, WA
Article doesn't say if it was an electric heater or a propane heater. I can't imagine someone running an onboard genny to power an electric space heater (very inefficient use of resources) so it was probably a propane heater.
She's parked on the street, so it's highly unlikely she was plugged in.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
beemerphile1
Ohio
Maybe this was the heater:
![[image]](https://c8.alamy.com/comp/DT0JER/tea-light-candle-and-flower-pot-heater-DT0JER.jpg)
This stupid suggestion is all over Facebook the last couple of days.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
coolmom42
Middle Tennessee
Edd505 wrote: coolmom42 wrote: That's sad. And I doubt she has adequate insurance to replace it, even if she could replace it, and now she's homeless.
It's very easy to check the cutoff switch, and I always do that fairly often. All you have to do is pick up the heater, or tip it.
bucky
Raleigh metro
fire clicky
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
bukhrn
Lanexa, Va
coolmom42 wrote: Edd505 wrote: coolmom42 wrote: That's sad. And I doubt she has adequate insurance to replace it, even if she could replace it, and now she's homeless.
It's very easy to check the cutoff switch, and I always do that fairly often. All you have to do is pick up the heater, or tip it. X-2, I don't have to pick mine up very far,3/4" it shuts off.
2007 Forester 2941DS
2014 Ford Focus
