RV.Net Open Roads Forum: Tech Issues: How to sanitize new RV water system
 > How to sanitize new RV water system
CabinetmakerII
Idaho
Posted: 02/18/21 10:24am Link  |  Quote  |  Print  |  Notify Moderator
While dumping tanks the other day I was looking at the "Water Control Panel" and got to wondering how to sanitize the fresh water holding tank. All of our previous RV's had a gravity feed fill port for putting water into the fresh water tank. When sanitizing the system I would simply pour a measured amount of bleach into said port and fill the tank. Run the water pump to get the bleached water into the system and let it sit overnight. Then drain and flush the system the next day. Now to the issue at hand. On this new coach, the "Tank Fill" is controlled by a valve. Simply turn the the City water valve to the Tank Fill position and the tank fills... How then do I introduce bleach into the system? Is there a siphon type connection available to put onto the bleach and the water flow takes it to the tank? Any advice would be appreciated!
Allan
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2006 700 Arctic Cat ATV (X2)(Retired)
2014 Kawasaki Tyrex 4LE Side by Side
RobWNY
Jamestown, NY
Posted: 02/18/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
How I do it is, I unhook my hose from the spigot, pour about a cup of bleach into the hose using a small funnel and then reattach the hose and turn the water on. I fill my fresh water tank and then proceed just as you do. Draw water through the system with the pump, let it sit about 24 hours and then drain everything out.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Rangerider
No Va
Posted: 02/18/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Same here. Put the bleach in the hose.
CabinetmakerII
Idaho
Posted: 02/18/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
OMG! How simple is that! Thank you for such a simple solution! Who feels stupid now?
TenOC
On the road -- Full time
Posted: 02/18/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
My 5th wheel has a freshwater tank overflow/vent near the back of the 5th wheel is covered with a small white square piece of plastic about the size of one's hand. To remove pull up sharply and you have a gravity fill place.
Check out the photo on this posting
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
CabinetmakerII
Idaho
Posted: 02/18/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
There is no such fitting on my RV... the tanks vent is a small hose (3/8"?) that has a tight mesh screen over it to keep the bugs out.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 02/18/21 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Use genuine not artificial vanilla one cup per 50 gallons overnight to deodorize. It's magic [emoticon]
Bumpyroad
Virginia
Posted: 02/18/21 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
when I was using filters that took cartridges, I just took a cartridge out, poured a bunch of bleach in and ran the water in thru the system.
bumpy
DrewE
Vermont
Posted: 02/18/21 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
The easiest way is probably to introduce the bleach into the hose, as others have said. That's what I do (and I have a similar setup).
If you have a winterizing suction setup, you could also use that to suck a bleach solution from a container and into the tank. You can similarly use it to suck in potable water, for that matter. Just set the valves to "winterize" and "fill" at the same time.
I think one of the main reasons why some RVs don't have a gravity fill port is that the fresh water tank is located higher off the ground than is convenient for a fill or hose connection. That's the case for my motorhome; the tank is contained in the bed base, and its top is maybe five feet above the ground. If there was a gravity fill port, it would have to be above many people's heads.
Sjm9911
New Jersey
Posted: 02/18/21 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Addtionally they sell a hand pump you can attach to the city water port. I use the pump winterizing suction as i have no gravity fill on my TT. But i did buy the hand pump. Took me a while to figure out out to use the pump for the antifreeze, bleach.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
