RV.Net Open Roads Forum: Class A Motorhomes: Cost of engine replacement or rebuild
 > Cost of engine replacement or rebuild
rhagfo
Portland, OR
Posted: 02/19/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
I have over 200,000 on my 7.4. Treat it right and you should get that kind of miles. No engine work, just routine maintenance.
Long block is about $3000. add in external components another $1500. Installation will put cost up to nearly $10,000.
Maybe 3k oil changes if that is all that it is driven in a year, but that is real old school! Most gas engines now state 5k to 7.5k, the oil and additives today are far better than in years past.
I changed the oil in my 2001 Cummins at 10k and when I needed to change the tappet gallery gasket at 300k it was clean.
Best to have it analyzed when changing.
naturist
Lynchburg, VA
Posted: 02/19/21 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Totally irrelevant and off-topic, but may provide some relief of the shadenfreude sort for the OP: my son in law recently blew the engine in his Porsche: a rod came through the block. His new engine is going to cost him $40,000. Be glad your RV isn't powered by Porsche.
Teleman
Clayton, CA, USA
Posted: 02/19/21 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
My mechanic told me he'd kill me if I bought a German car lol
Rocky2
Ventura, Ca.
Posted: 02/19/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
My 8.1 Vortec had 93,383 miles when it blew. Why? The catalytic converter created so much back pressure it blew the seals out and pumped the oil out at 55mph. It was just short of $10k to have all the work done.
Teleman
Clayton, CA, USA
Posted: 02/19/21 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
Ouch! Was there a way to know that your CC was malfunctioning? I've never heard of this.
chuckftboy
Fleming Island, Florida
Posted: 02/19/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
That Porsche engine probably came out from under the car. Maybe 10 thousand in parts and 30 thousand in labor LoL!!
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Gjac
Milford, CT
Posted: 02/20/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
I have a 125,000 miles on mine now with just spark plug, wires, distributer cap and rotors changes. As Bud said I worry more about the transmission, so I change the filter and fluid every 30,000 miles or so along with the rear end fluid. I think Headers, FF muffler sans cat, and a CAI will help it run cooler, add about 80 HP, and give it a longer life. 454's run hot so these mods will help it run cooler which will add to the engine and transmission life. My engine uses about 1/2 qt of oil between oil changes every 7000 miles or so. Every 3 years or so I run Seafoam or Berriman's B-12 through the TBI just to keep the top end clean and every 5 years through the crankcase. Syn oil will also keep the crank case clean. A friend had a crate engine install for about $9000, watch the heat and maintain it and you will see 250,000 miles if not save $10,000 for an engine replacement.
olfarmer
Iowa
Posted: 02/21/21 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I worry more about the transmission, wheel bearings, belts, hoses, etc. than the engine. Our MH is low mileage (under 30k) but it is 20 years old so many thing can fail from age!
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
Teleman
Clayton, CA, USA
Posted: 02/21/21 08:56am Link  |  Quote  |  Print  |  Notify Moderator
A good thing is that I haven't seen the temp climb at all even in first gear on steep hills. I haven't driven in hot weather yet though.
Gjac
Milford, CT
Posted: 02/22/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Post back in July and let us know how you do. The real test is a 90 degree day on a long incline. There are a number of things you can do if it runs hot.
