RV.Net Open Roads Forum: Truck Campers: Who’s still using a 7.3 diesel truck
 > Who’s still using a 7.3 diesel truck
Page of 12
NRALIFR
Truck Camping Out West
Posted: 02/22/21 04:28am Link  |  Quote  |  Print  |  Notify Moderator
Jtime wrote:
Kayteg1 wrote:
ticki2 wrote:
And almost none of it has anything to do with a truck camper
So is about 90% of this forum replies.
At least less trolling than usual and I'd say the topic was pretty constructive.
I agree lol. Which tires does everyone run on your duallys or which would you recommend?
The 7.3’s came with 16” inch rims is it worth the extra coin to jump up into a 18 or 20?
I would be concerned about the clearance in the front wheel wells making that big a jump in size. The turning radius is already bad for these trucks, if bigger tires rub in a turn, it’s going to make that worse. There’s also the question of increasing the unsprung weight with the bigger tires and wheels. That can have a negative affect on the braking performance, especially with the rear drum brakes if yours has them.
There are tire options in 16” size that have higher ratings than OEM. Michelin XPS Traction is one, but I know there are others that are probably going to be easier to find. The XPS traction is turning into a rare bird, and there are only two sizes still made.
The least expensive way to get higher rated wheels is to just buy six steel Accuride wheels that were made for the E450 vans of the same year. If you want great looks too, get four Alcoa’s and two Accuride wheels. Whatever you get, make sure the wheels are hub-centric, not lug-centric. No eight to ten lug adapters either.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
mellow
Salisbury, MD
Posted: 02/22/21 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Jtime wrote:
mellow wrote:
I hate the picture capabilities of this site.
Here is mine:
Dang!! Which model is that TC and what’s your camping weight?
Lance 1191 that is in my signature. Camping weight as in full of water for offgrid camping like I do? Not going to get the weight police going on that one, I am heavy which is why I upgraded to a DRW.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
mellow
Salisbury, MD
Posted: 02/22/21 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I went with these tires, they are working great so far, especially in 4x4:
General Grabber A/TX - #04508440000
All Terrain Truck SUV
NRALIFR
Posted: 02/22/21 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
A picture from the last trip we took in the 1995 F350. October, 2010 in California, and this was taken on a twisty road between Caliente and Bodfish. The boss lead us there because it’s such a scenic and challenging route loved by............motorcyclists. She missed the motorcycle part.
Loaded with gear for a 2-3 week trip, it weighed about 12,700.
Kayteg1
California > Nevada
Posted: 02/22/21 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
That's not too much.
I weight my aluminum dually at 12,800 and that was before I loaded Alaskan beer and salmon.
NRALIFR
Posted: 02/22/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
But..........mine was over its GVWR by 2700 lbs so it should have exploded and wiped out an orphanage and a convent. [emoticon] [emoticon]
Jtime
North
Posted: 02/22/21 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Kayteg1
California > Nevada
Posted: 02/22/21 11:37pm Link  |  Quote  |  Print  |  Notify Moderator
So you blew your tax report as if you had 10k lb rating on dually, it was all taxation.
Duallies in most of the states come with 14.9k lb GVWR, while axles ratings total in the range of 16-17k
jimh425
Western MT
Posted: 02/22/21 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
No, DRWs don’t come with 14.9K GVWR. I think you meant 14.0K GVWR, but the axle ratings are even higher than 17K.
* This post was edited 02/22/21 11:55pm by jimh425 *
NRALIFR
Posted: 02/23/21 06:09am Link  |  Quote  |  Print  |  Notify Moderator
No, I did something even better. I just didn’t worry about it.
I did enjoy trolling those who did, though.
Still do, a little. [emoticon]
Page of 12
