RV.Net Open Roads Forum: Tow Vehicles: 2020 sales
Search only in Tow Vehicles
 > 2020 sales
Bionic Man
Colorado
Posted: 02/20/21 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Put me in the camp that RAM absolutely needs to change to an 8 or 10 speed. It will drive better. It will be better for marketing. And it would allow them to simplify to one transmission for both 2500 and 3500 trucks, and get them competitive power levels for those that buy a 2500.
An upgraded transmission would probably be enough to put me in the market to upgrade.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Cummins12V98
on the road
Posted: 02/20/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
"To a point I agree. I've been very happy with the 6-sp in our Cummins. However, my comment is more about "sales and marketing" than raw performance."
I agree most people "THINK" they need more gears. Gas pots and the V8 Diesels may find usefulness in the 8-10 but i can tell you another two or 4 gears won't make a hill of beans difference with the CUMMINS.
Bionic, you don't have the AISIN with it's very low starting gears. It truly makes a difference over the 68RFE especially with the 3.42's. When my truck downshifts it's a measly 250 rpm's between gears.
The AISIN is what they call a "Bullet proof" trans, I will stick with that.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
otrfun
On The Road
Posted: 02/20/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Good point.
Not sure what Ram gains by offering two different drivetrains. The base level 6-speed 68RFE/Cummins SO offers less torque/HP/gears than Ford & Chevy, but is priced roughly the same.
The 6-speed Aisin/Cummins HO option has an overall MSRP that's *higher* than Ford & Chevy, even though it's overall performance/capability is arguably less (less HP; equivalent torque to Ford; but no 10-speed tranny).
Also, by offering the Aisin (which has the same 6-speeds as the 68RFE), Ram is inferring the 68RFE (which makes up the vast majority of Ram's sales) is lacking in some way. Not a good marketing strategy IMO.
I think Ram would be much better served offering one drivetrain (like Ford & Chevy) that's competitive across the board. It would certainly reduce production costs and simplify marketing.
Cummins12V98
on the road
Posted: 02/20/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
"Also, by offering the Aisin (which has the same 6-speeds as the 68RFE"
Technically true but the fact is the AISIN has lower starting gears and easily get's my 35k rolling on steep grades.
ksss
Eastern Idaho
Posted: 02/20/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
The points made about offering to different transmissions are spot on I think. It doesnt make a lot of sense both economically and conveying the message the cheaper tranny isn't sufficient. The Ram may actually be a better truck with a ten speed. The change the ten made in the GM trucks is really pretty amazing. I know that is not a direct comparison to the Ram truck, but I am not sure why a Ram owner would be against having a ten speed especially if you have driven one. GM has done an amazing job dialing in that tranny, almost feels like a CVT it is so smooth.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
FishOnOne
The Great State of Texas
Posted: 02/20/21 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Ram doesn't need a 10 speed transmission until cummins12V98 buy's one and then the raves begin. You know the drill! [emoticon]
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
on the road
Posted: 02/20/21 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
larry barnhart
wenatchee. wa usa
Posted: 02/20/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
I never felt our 05 duramax needed a 6 speed. But if ya never drive one maybe it would be better. I never drive a newer truck than I have unless I am thinking of a trade. Happy is the best. chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
blt2ski
Kirkland, Wa
Posted: 02/20/21 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Larry,
I would have liked a 6th DIF in my 05, along with 410 gears. BUT with this said, I do mostly city driving, so having lower starting gears us better for me. Even 4.33 with a DOD put me at about the same final ratio iirc vs the 5 so 5sp.
Realty, the ally 2200?!? Has the same gears as asian dodge used. that's in reality, best setup from my driving style. Too bad we don't get multiple tranny, gear ratio and HP/Torque spec options like some mdt setups give you.
Marty
Check RV.Net Blogs at: blog.rv.net
FishOnOne
Posted: 02/20/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
[emoticon]
Or the other one "Buy one and you'll thank me later" [emoticon]
* This post was edited 02/20/21 04:02pm by FishOnOne *
 > 2020 sales
